Home Logo
Posted on Jan 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the 1 decimal place for this no 0.66239527
David Shaub
Level 3:
President:
  • Master 2,994 Answers
  • Posted on Feb 06, 2012
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1152536
Points
8370
0
If you mean first, it is tenths. (or .7)
Rounding decimals 3 places
You round a number with several decimal places to a number with fewer decimal places.
1.14 rounded to 1 decimal place 1.1
What you are asking for can be done by putting a zero after 4 and write 1.140, BUT that is not rounding. In fact you can put as many zeros after 4 as you want.
Decimal places
Press f then a digit representing the number of decimal places you want after the decimal point.
What is the default setting for the f cut 5/4 and the 4320 add 2 I don't know what to have these options set at thanks EW Seattle
The selector you are asking about is the "decimal selector". The result displayed/printed, will be in a format according to the position that you have selected as follows:
f = floating (the result will be in the number of decimal places that were entered on the keyboard
4= fixed 4 decimal places (x.0000)
3= fixed 3 decimal places (x.000)
2= fixed 2 decimal places (x.00)
0= fixed 0 decimal places (x)
add 2= (add mode*,fixed 2 places) ($.00)
Note* "ad mode" automatically enters the decimal place when entering the number on the keyboard. If you enter "123", the displayed ammount will be "1.23". If you enter "1", the display will read ".01". This is a useful setting when adding a list of numbers in a dollars/cents format, however, be careful, if entering a whole dollar ammount "three dollars" be sure to enter the decimal point, or enter the number as "300". If you don't, the result will be ".03", instead of the 3 dollars you intended.
1helpful
Explain "CUT", "UP", "5/4"
CUT: Values are cut off to the number of decimal places speicified by the current Decimal Place Selector setting
UP: Values are rounded up to the number of decimal places speicified by the current Decimal Place Selector setting
5/4: Values are rounded off (0,1,2,3,4 are cut off; 5,6,7,8,9 are rounded up) to the number of decimal places speicified by the current Decimal Place Selector setting
1helpful
Decimal placing
Above the feed button is an area for controlling the decimal placement. By leaving the slider on +, you have to manually put the decimal in.
0 - Means no decimal will be placed.
1 - Put it one place to the end. Ex: 4132.5
2 - Will make it read 413.25
3 - Will be 41.325
And so on.
4helpful
Only shows 1 decimal place!!
Press 2ndF TAB and then a digit specifying the number of digits you want after the decimal point.
8helpful
Need to program to fifth decimal place
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][5][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
39helpful
I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
