Burning smell from sym orbit II Burning smell after 10 km * + Chris mcwilliam 5 hours ago ( [email protected] ) * plastic or rubber - something very much hotter than it should be but no smoke..... the bike is 4 weeks old and has done 108 km and i have refuelled the tank once with 98 unleaded . Lube oil level is fine. Is this smell to be expected from a brand new scooter from the exhaust casing? thanks. 2. Details
SOURCE: 2005 nissan murano "s" surges and bucks when accelerating.
You need to have your engine flushed and cleaned out. One or more of your spark plugs aint firing. You need to replace them all to include the wires as well. If you dont get your engine flushed, you could blow your engine up.
SOURCE: Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
SOURCE: rubber burning smell and smoke
It sounds like a pulley froze up. Pop the hood have someone start the car while you are looking at the pulleys, you should be able to see the problem.
SOURCE: what sort of oil does my sym orbit 50 scooter use?
The engine needs 10w40 motor oil. NEVER use synthetic oil or oil with special additives.
SOURCE: Smoking Craftsman Riding Mower
1st thing, check your dipstick up inside the cap part of it and make sure the O'ring is there and in good condition.
2nd, make certain when you put it back on that you get it on straight and firmly seated. They will only seat one way properly the other way creates a leak into the crankcase and causes oil consumption and smoking. You should be able to tell if it has been improperly installed by an excessive amount of oily dirt accumulated around the threaded area of the cap
