Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you need more help with this post a reply hope this helps you
SOURCE: my 4gb scan disc sd card wont format
http://www.sandisk.com/Retail/Default.aspx?CatID=1668
I believe sandisk makes a special program to format their cards
Robert
SOURCE: trouble in formatting my SD micro sd for my lg chocolate cellpfon
use some other card reader for the purpose and format it from there.
SOURCE: when i insert my 8 GB micro SD card it says the same thing.
Your 8GB card is considered "high capacity". You will need an SDHC USB card reader to read it.
SOURCE: i put my 16g sd card in my phone but it keeps saying insert an sd
it could be that your phone does not support high capacity sd cards (SDHC). Check the users manual to see what types of cards it supports and if SDHC is listed.
SOURCE: i have a 2GB micro sd card for my blackberry when
if this card working on yours phone then this problem related with window operating system if card have problem with phone then this is relsted with card , formatt this card with phone and restore it by system restore s/w.
