I have just bought a wireless control pad for my ps3 model num JRH-1018A1 and cant get it to work it also came with a little white usb stick obviously to do with the control pad being wireless please help
I'm having the same problem... Only when I click my PS button, it flashes, normally. Then again, it's faint, and very, very fast, machine-gun-like flashing. And it's really annoying. Who knows how to fix this problem? I've tried resetting, there's no way to connect the controller with the console it's self, I've tried using the wire to connect it... No luck, nothing's happening. Please help?
SOURCE: PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
SOURCE: PS3 USB ports won't work
Yes I have, a known good one. I can connect to my laptop and the controller charges.
I bought a new controller that connects wirelessly via the USB port. When I plug in the USB adaptor, I get a green light briefly and then it goes out.
SOURCE: PS3 controller does not work after 2 weeks.
Had PS3 2 months and action button X on controller,
not working called Sony they will replace controller. Tried different ways to connect even shut power on PS3 still same
problem...
SOURCE: CECHZC1E -Wireless Controller
the standard Sonuy cotroller does not have vibration.
There is a new one on the market (can't recall the name right now also made by sony). Runs about 75 dollars.
SOURCE: The usb for my wireless guitar hero world tour drums cant connect
i had the same problem, all i needed to do was change the batteries in the drum kit
