Question about Ricoh Aficio 120 Copier
Code erreure sc 300 aficio mp 6000 - Ricoh Aficio 120 Copier
Carl quenneville
    New Friend:
  • 33 Answers
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Posted on May 03, 2016
5 Related Answers
Anonymous
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: ricoh aficio 1035 sc code sc 329 troubleshooting
Laser diode beam not positioned correctly. Turn the machine off and back on and see if it goes away. You can run sp 2109-3 or 2109-4 in the service mode to adjust the beam in service mode by pressing on the yellow button. pressing the 107 keys and holding down on the clear button.
If this doesn't resolve the issue, you probably need a laser which we have one for sale here.
Posted on Dec 17, 2008
Anonymous
  • 126 Answers
SOURCE: sc 481 on my ricoh aficio 1224
moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Posted on Jan 08, 2009
Joseph Micallef
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
Anonymous
SOURCE: Ricoh Aficio 1232 c SC-101 and SC-142 codes what do they mean?
It is a scanner problem....could be lamp, lens defect, or as simple as the lamp, and lirrors undeer the glass being very dirty, because the code refers to the 'white level"....a calibration that the machine does when switched on. It could be as simple as, the white plate which is underneath the left scale (beside the main contact glass) is dirty (or missing). Try cleaning this (2 screws), and while you're at it, try removing the main contact glass (3 more screws)and cleaning it as well as the scanner bulb, and mirrors (slide scanner to the right with the machine unplugged).
Good Luck
Posted on Mar 02, 2009
Where are the ID/SENSORS in my photocopier ricoh aficio mp 6000
my dear you clean drum unit your trouble codes clear
Jul 16, 2015 | Ricoh Aficio MP 6000
Jai un C3500 mp Aficio de Ricoh qui a sc erreur 792
finisher cable not plug into copier. I f you don't have a finisher don't worry about it or you need to remove bridge unit to get rid of code.
Sep 20, 2014 | Ricoh Aficio Mpc 3500 Color Copier
I have copier it given me this code SC 544 & SC 542 & SC 500 can you assist me please .
overload of the main motor or fusing unit (SC 500)
Look at your fusing unit, (rollers, thermistor, lamp, gears...)
and don't forget to reset SC code in SP mode.
Good luck
Jul 03, 2011 | Ricoh Aficio MP 161 Black and White Copier
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Ricoh Aficio MP 6000 copier with error code SC555
there is no sc 555 on those machines only sc 550 and that relates to what is called a fuser web.It does need to be changed but you can reset it by pressing the following in order
1- yellow clear key
2- number 1
3- number 0
4- number 7
5- press and hold down the orange clear/stop key for 5-10 seconds.
the screen changes
select copy sp
select sp 1
scroll down to SP1902 001 and select
reset that value to 0 and select enter
switch machine off and on and that should get you going for now.
Let me know
May 23, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh Aficio 120 Copier Logo
267 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
