Canon Speedlite 430EX TTL Flash Logo
A
Anonymous Posted on Jan 17, 2012
How to take a 430EX II TTL Flash apart? - Canon Speedlite 430EX TTL Flash
5 Related Answers
Glennzie
  • Posted on Apr 15, 2009
SOURCE: canon 430EX flash will not flash in slave mode.
This site worked foe me http://flashzebra.com/wizardcables/index.shtml
Good luck
Anonymous
  • Posted on May 20, 2009
SOURCE: I have a Cannon EOS
I posted this over at POTN:
Bringing up a minor-aged thread; but I wanted to add some information that may help others. Here's the best I can remember of what happened earlier...
Tonight, I had one of my three 580II's sticking in TTL. I grabbed another 580II and got the same issue. Then, I grabbed another 5DII, mounted one of those flashes and everything was fine. So far, it seemed to be a camera issue. Out of curiosity, I took the flash that was working and put it back on the first 5DII. Again, the TTL sticks and I think it's more mount related than camera.
I was baffled and a little pissed, but in a hurry; so I didn't think on the spot to take a moment to go into the camera's menu and check settings. I can say that I did check all CFn's, the exposure comp and both flashes on both cameras and everything was fine according to the LCD panels (not screen) on all. I also hand checked all the settings on the flash(es).
Here's how to fix it... it's generally NOT a connection issue from what I have concluded. If you have a 580II sticking in TTL...
I can confirm that the ONLY thing that fixed the issue was to check the settings THROUGH the camera's menu. By doing so, I found the flash exposure comp was dialed down 2 stops on the flash in question - BUT it DEFINITELY was NOT showing this on any screen - either camera or either flash. Everything was set right on the LCD panels. (not screens - I generally only use those for chimping. :D) The result was images were near completely white. Shooting in any mode would not fix the issue. You could not compensate. Even adjusting the EC at cam had no effect - even in M. So, check your FEC THROUGH the camera's back screen. This is (and only) where you will see the issue if it's not a connection problem.
I do believe there's some kind of internal (software?) issue with the 580II's and that's how I remedied it. However, it did only happen on one camera. And while it only happened on that one camera, I can say that as soon as I changed the EC through the screen, it was fine - without touching the connection. I did not experience any loose connection; that's for sure.
From a little research, I found this is a fairly common problem with the 580II's and resides in nearly 100% of the time with the flash as it happens on multiple camera models. However, it's easily remedied if you do the above in bold. ;)
Just FYI and hope it helps.
edit: Just wanted to add that these flashes have never seen moisture and even the camera menu showed "ETTL" when it was in fact not showing that on the flashes screen. Anyway, look at the FEC in the menu. ;)
MIke
  • 685 Answers
  • Posted on Nov 21, 2009
SOURCE: Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Anonymous
  • 691 Answers
  • Posted on Dec 03, 2009
SOURCE: Canon 430EX II flash... batteries A-OK. But flash
Hello
Thank you for using FixYa for your problem
Sounds like the flash tube has gone.
It should be taken to an authorized repair centre for a repair estimate.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Tom
  • 78 Answers
  • Posted on Jan 21, 2011
SOURCE: Canon 50D doesn't recognize new Speedlite 430EX
Check the contacts on both the camer and the lens. I usually clean mine with methylated spirits or isopropyl alcohol. I have to do this every 3 months or so as dirt or even oils from your hands can stop the contacts from working properly.
Canon 430ex ii seems to flicker rapidly sometimes before taking pictures
Yes it is. The system is simply measuring the flash to meter the exposure.
Speedlite 430EX II pilot red light wont turn off wont fire
Try mounting the flash on your camera, turn both on and reset your camera to factory default settings in your camera menu settings.
Battery acid damage on canon speed light 430ex
You'd have to open up the flash (I don't recommend) and replace it by soldiering a new one in place. If you can't make you're own contact or salvage/fit one from another source you must send it in for repair.
Canon 50D doesn't recognize new Speedlite 430EX II. Flash power is on and pilot releases flash.
My xti fell with the 430 ex II attached now it
The hot shoe was bent slightly causing the flash contacts to not touch those of the camera. By using a socket from a socket wrench set, place it over the grids of the hot shoe and tap firmly with a hammer to straighten it.
2helpful
Canon 430EX II flash... batteries A-OK. But flash doesn't fire... tried pilot... doesn't work
Hello
Thanks
Richard Scott
Technical Support
New Zealand
6helpful
Can't find the serial number on my 430EX speedlite. where is it located?
This is where I found mine:
It's a 6 digit number located on the top half of the flash (the bit that tilts backwards and forwards). On one side it says Speedlite 430EX II, on the other side there are a few symbols and underneath is the serial number engraved on the plastic.
I also found it printed on the warranty card that came inside the box.
Canon speedlight 430EX II won't fire
The conceting piece of the Flash has cracked when i dropped it, is there any thing i can do to repair or exchange it?
Canon Speedlite 430EX TTL internal corrosion.
U are to be commended on your industry. Those cameras are a bit-- to take apart. Try a google search for the operation described. You might get lucky with a utube video!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
