Question about Tappan 30IN ELEC IGNa Oven
Tappan stove error code f11 - Tappan 30IN ELEC IGNa Oven
Posted by ivoryington on
HOW TO SOLVE TAPPAN OVEN MGF334BGWA FROM COMING ON AND GOING OFF RANDOMLY
Thank you for your post, friend!
I understand that your Tappan stove is coming on and off randomly. It sounds like a possible issue with the switches or control panel. I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this is helpful. -Matt
Oct 18, 2014 | Tappan Ovens
My tappan oven won't work. stove and broiler work fine. ignighter glows but it seems like there is no gas.
I would check with your manufacturer and see if a professional can diagnose the regulator and even the gas valve itself.
Jul 17, 2012 | Tappan Ovens
Error code f11
I do not know what the error code f11 means on your appliance but I do know that if you cannot find it in your manual you will obtain the information you require from the manufacturer or a reputable dealer or service engineer. If this error code relates to an open door and you are satisfied the door is properly closed then the switch that closes the circuit that permits your oven to operate is not operating. This may be due to the oven door seal stiffness being just enough to keep the switch contacts apart or it may be due to dirt or grease preventing a clean electrical contact being made.
Jan 17, 2012 | Tappan 30IN ELEC IGNa Oven
Does this tappan stove require a hood for ventilation? The one I have is intalled in the center island of the kitchen.
You don't have to have a hood over a stove. If you do though it removes all steam and odours. The grill also catches all the cooking fats. Your kitchen will stay a lot cleaner if you have one.
Feb 11, 2011 | Tappan 30IN ELEC IGNa Oven
Tappan range error codr f5
Hello,error code f5 means temp too hot Replace oven temperature sensor
Thanks
May 26, 2010 | Tappan 30IN ELEC IGNa Oven
Tappan gas stove take long to light then theres a boom
you need a new ignitor.. the ignitor isnt getting hot enough to ignite the gas
Mar 10, 2009 | Tappan Ovens
Installed a new Tappan stove electric
check if there are links on the mains connector block and if so, make sure they are tight
Aug 10, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan 30IN ELEC IGNa Oven Logo
377 people viewed this question
Top Tappan Ovens Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Tappan Oven Expert? Answer questions, earn points and help others
