I need to take the bottom of the case off to replace the bottom shell because it is cracked but i cant figure out how to get it apart? i have removed all visible screws on the bottom and under the cd drive and still cant get it apart. it almost feels like there is something on the inside of it holding it together that i cant get to. can someone maybe write me step by step instructions to get it apart? thank you
You may remove the bottom case by following the instructions mentioned in the link below:
http://downloads.dell.com/Manuals/all-products/esuprt_laptop/esuprt_vostro_notebook/vostro-3500_service%20manual_en-us.pdf
Note: Please refer to the index for specific instructions.
Hope this helps..
SOURCE: Need to take a C400 apart
For dell computers. you need to start from the keyboard down to the bottom. use this link to guide you. http://support.dell.com/support/edocs/systems/latc400/en/sm/index.htm
SOURCE: Dell Inspiron 1000 Disassembly
Dear RBROWN67,
you can find the service manual for you DELL Inspiron1000 Notebook , from these URLs:
http://support.dell.com/support/edocs/systems/ins1000/en/index.htm
http://repair4laptop.org/disassembly_dell.html
Hope these sites are helpful for you in future also.
Cheerup and Be Happy always
SOURCE: Replacing a dell inspiron 1525 LCD screen
u no the ruber things that are on the screen so it is soft when u close it just pull it of and the screws are under there
SOURCE: My ethernet port is not working. I have not used
the most popular solution is installing os........
but if u don't wanna so first u have any cd of your ethernet port....
so u can install second time and enjoy
ok
have a good day
What were you opening the laptop for? Depending on how much of it you had to disassemble, I would venture to say you probably left something unplugged. I would crack the case open again and check all connections, make sure the hard drive is fully locked into place, etc.
