Question about Integra Audio Players & Recorders
No sound on my Integra DTR 80.1 with any components. Everything connected properly. I have power. Can you help?
Posted by Russ towers on
5 Related Answers
Anonymous
  • 9 Answers
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
Peter Bradley
  • 57 Answers
SOURCE: my left rear speaker has no sound. All others
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Posted on Nov 26, 2009
SOURCE: Integra dtr-6.3 receiver: Red standby light
your receiver is having a power problem. The power supply board is defective that's why the receiver won't power up. Its receiving power but it cannot transfer the current to the necessary part of the receiver because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the capacitor might not come on.
This may have occurred as a result of power surge/irregular power supply/excess power supply entering into the unit. This is usually common with receivers and electronics as a whole.
If you know about electronic repairers, I would suggest that you open the receiver and read the power board/panel with a meter, detect the bad component and replace it.
But f you don't know about electronic repairers, take the reciver to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Dec 02, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have a Integra receiver
NO sound at all? That would be odd as its internal FM receiver is independent of any user connections. I'd work on getting FM to work first, then move on to more complex issues.
The manual is here:
http://www.retrevo.com/support/Integra-DTR-6.6-Receivers-manual/id/550ag000/t/2/
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Posted on Dec 26, 2010
electrotech1
Veril Gillette
  • 1126 Answers
SOURCE: my integra dtr 5.6 receiver
It sounds like a bad power supply that is nor feed the votage to the display, or the main processor is locked up and to unlock the processor you need to unplug the unit for 40Min, and it will reset back to normal.
Posted on Jul 30, 2011
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Integra receiver 40.4 wont play ipod again
is it set properly for that input? does it play on the tuner setting? check the connecting cable for breaks..
Feb 02, 2014 | Integra DTR-5.1 Receiver
No sound
Sounds like an input button has been changed. Check that out first
Jan 11, 2014 | Integra DTR-7.1 Receiver
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
I have a Integra receiver model number DTR 66 and I have no sound. it appears to have everything connected and should be working. I would like to know how to reset the receiver or what steps do I need to...
The manual is here:
Dec 26, 2010 | Audio Players & Recorders
Doing a job for a friend. Reconnecting all his gear to an Integra DTR-7.1. Everything works except for the surround. I can't get the rears to speak from the receiver. I have verified they work (wires...
if you have everything connected properly, then it wont necessarily utilize ALL of the speakers, unless you have a true 7.1 signal coming in. is it using optical or coaxial? make sure that the options on the receiver are set right......the rears on 5.1 and 7.1 dont work unless they are told to by the receiver....and the signal coming in from the external source ( dvd player, ps2, ps3, xbox....) tell the receiver what it is going to need, in order to utilize the full signal. everything is labeled, and it sounds like you know what you're doing, when it comes to hooking this up, which is always good. it sounds to me, like something isnt configured properly, so i would start there. it may take a while, but you get the idea.....
Sep 24, 2009 | Integra DTR-7.1 Receiver
Jun 30, 2009 | Integra DTR-5.2 Receiver
No output to subwoofer per-amp
you may have to go into the onscreen menu and enable it,that shuld work
May 11, 2009 | Integra DTR-8.3 Receiver
No sound from speakers from components with Integra 6.9 receiver
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
655 people viewed this question
Top Integra Audio Players & Recorders Experts
Bill DiBrino
Level 1 Expert
Naheed Mir
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
