Question about HP Photosmart 2575 All-In-One InkJet Printer
HP Photosmart 2575 All-In-One, prints black but all blur and inaccurate, no colours
What could be the problem, I have changed the cartridges and they are originals. Connected with USB to Windows 7/64. Automatically when i put the cable in the printer was added as "2570 series...." and was green meaning works fine in connections and program. However printer prints thick gray blurry inaccurate text, not to mention that no colours at all. Any good ideas to fix this?
Posted by Mikael Keinonen on
  • Mikael Keinonen Jan 18, 2012
    Thanks for the prompt advise, I do not have this software for cleaning. Could you give me a tip or link from where such software could be downloaded.
    YES you have absolutely right, the printer had not been used for couple of years. If can be made to work, I would be grateful. I almost lost hope... but you guys seem to know a lot. Appreciate your futher assistance.
  • Lukas Margetak Jan 18, 2012
    Choose your operating system here http://h10025.www1.hp.com/ewfrf/wc/softw...
    then "HP Print Diagnostic Utility"
Lukas Margetak
    Sergeant:
  • 219 Answers
Hello Mikael,
you need to clean head on your printer. This is usually done via software that came with your printer. This usually happens, if you do not use your printer regulary, the ink dries and causes problems like this.
Posted on Jan 18, 2012
5 Related Answers
Anonymous
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
ad74983.jpg Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
0e1481b.jpg and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
Posted on Feb 22, 2008
Fred Fisher
  • 51 Answers
SOURCE: Cannot get printer to accept new tricolour ink cartridge.
What is the cartridge number
Posted on Dec 01, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: ''HP 2575 printer prob
Clean the scanner glass
Posted on Feb 21, 2009
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
SOURCE: is there a difference in drivers for the hp 2575
Below is the link where you can go and download the drivers and firmware.
Click Here to download
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 09, 2010
UNCLEZEB
SOURCE: PHOTOSMART 2575 DISPLAYS "MEMORY CARD
Insert a memory card (in my case a SD CARD) and SLOWLY extract card until error message clears and normal screen images appear.I had to do this several times but it worked for me but cannot guarantee it will for everybody.GOOD LUCK.
Posted on Jun 22, 2011
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
Can you use 2 black cartridge instead of 1 black 1 colour in the HP all in one 2575 photosmart printer
You would not be able to.
The cartridge front is different and would not fit.
Also it is a requirement to have the correct cartridges to print.
Jan 11, 2011 | HP Photosmart 2575 All-In-One Printer,...
Hi Folks, Sorry to bother you but i have HP 2575 all in one for past 3 years,and until now had no problems..I recently changed my colour ink cartridge cos the old one indicating low toner and some colours...
Try to clean the cartridges by taking them out and trying aligning the cartridges again... try the alignment if you have any software named as image zone or solution center
Oct 21, 2010 | HP Photosmart 2575 All-In-One Printer,...
A message comes up on the printer window saying remove and check colour cartridge. the cartridge is new and connections look ok
clean the cartridge contacts.... then align it.
To align the cartridges from the front panel follow the steps:
1. Press Setup.
2. Press 5, then press 2.
This selects Tools, and then selects Align Print Cartridge.
Mar 13, 2010 | HP Photosmart 2575 All-In-One InkJet...
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
My C6280 printer says the black is empty but it is
Dear Sir,
Printer doesn't identify the ink accurately all these are controlled by software only.So it is showing your black cartridge is empty but trace amount of ink actually remained,by this you are getting black and white prints correctly.After the consumption of that trace amount of ink it may print black text as a greenish-brown because printing taking place only by means of color cartridges.So if you observed blurred text or greenish-brown text, now you can replace your ink cartridges.
i think it helps
good luck
Aug 11, 2009 | HP Office Equipment & Supplies
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
HP Photosmart 2575 All-In-One InkJet Printer Logo
96 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
