Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 not printing on all the page, some text are missing
Posted by mickytatts on
Lexmark
  • Official Brand Answer
  • 3,344 Answers
What is the operating system installed on your computer? It could be a printer driver issue or could be due to clogged cartridge nozzles. Try the steps below to fix the problem:
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 5400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
If that doesn't help, please visit the Lexmark website to update your Lexmark X5470 printer driver. Select your operating sytem > click on FILTER > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation. Then try to print again to verify that the problem is fixed.
Posted on Jan 18, 2012
5 Related Answers
Anonymous
SOURCE: Print faxes in memory on a Lexmark X5470 All-in-One
I solved my problem by powering off, which I knew would lose the faxes in memory. However, I decided to have the faxes re-sent. As soon as I get time, I will address this issue with Lexmark. It seems incomprehensible to me that Lexmark does not provide instructions on how to do this.
Thank you for your interest. This simple question does not warrant a team to figure out--it is a manufacturer's responsibility.
Posted on Nov 11, 2008
Rachelkraj
  • 14 Answers
SOURCE: printer only prints one page of multiple page document
hi..
You may try to change the spool data format:
1. Click on "Start," "Control Panel," "Printers and Other Hardware" and "Printers and Faxes."
("Start," "Control Panel," "Hardware and Sound" and "Printers" for Vista...)
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark *** series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Try printing again.
Posted on Apr 24, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: how do i connect my lexmark x5470 with out cd software
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Posted on Jun 02, 2009
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Lexmark X5470 wireless
    This printer does not come with wireless capabilities. But if you want to connect it to your wireless network you can buy and external wireless USB print server which can help you connect your printer wireless.
    Posted on Mar 02, 2010
    printmastert
    Lexmark
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: Lexmark x4270 all-in-one problem with Windows 7
      I really appreciate your patience. Thank you for choosing Lexmark glhall53!!!
      Posted on Apr 29, 2010
      Can't use my x5470 on Mac 10.6.8
      Try to uninstall your existing printer driver. Then, reboot your computer after the uninstall process.
      Once your computer comes back on, visit the Lexmark website to download the Lexmark X5470 printer driver for Mac 10.6 at http://bit.ly/yRg5X8.
      Feb 07, 2012 | Lexmark X5470 All-In-One InkJet Printer
      My Lexmark X5470 just prints first page of multi-page document from PDF format. Can I do something about it.
      What is the operating system on your computer? What is the version of the PDF application you're using? It could be a driver issue. You can try to re-install the Lelxmark X5470 driver by visiting the Lexmark website at http://bit.ly/dbCiI6. Select your operating system, download and execute the file. After installation is successful, try to print again.
      Jun 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
      Lexmark x5470 will not print saying a component missing
      Hi
      Please check cartridge is properly fix and its not blank, check your USB cable, and uninstalled your printer driver and reinstall..
      May 18, 2011 | Lexmark X5470 All-In-One InkJet Printer
      I have a Lexmark X5470 printer and am having printing more than1 page. The 2nd page and following pages don't print and I get a paper jam messag.
      The rollers could need replaced or cleaning on the printer. Have a certified technician do a maintenance cleaning to resolve this issue.
      Jun 02, 2010 | Lexmark X5470 All-In-One InkJet Printer
      Have installed printer and it wont print.Seems printer drivers are missing .Where can i download these? Its a lexmarl X5470
      You can download the required installation driver from manufacturer's site by clicking this link
      On the page which opens, select the operating system (Windows XP/Vista,etc..) of your computer to download the appropriate driver.
      Hope this solves your problem. Thanks for using FixYa.
      Feb 08, 2010 | Lexmark X5470 All-In-One InkJet Printer
      What are the abilities of the printer x5470
      Lexmark X5470 AIO All-In-One Printer - Fax, Copy, Print, Scan and Photo (22N0000)
      Technical DetailsUp to 25 ppm black and 18 ppm color printing
      Convenient 10-page capacity auto document feeder for multiple page faxing and copying
      Fast borderless photos
      1-Touch PC-free copying (color or black)
      CIS flatbed scanner easily handles thick books, reports, and more
      Product Details
      Shipping Weight: 9 Kg
      Item model number: 22N0007
      ASIN: B000IZK1UG
      Date first available at Amazon.ca: Sep 17 2008
      Average Customer Review: No customer reviews yet. Be the first.
      Amazon.ca Sales Rank: #4,061 in Electronics (See Bestsellers in Electronics)
      Popular in this category: #33 in Electronics > Office Electronics > Printers
      Discontinued by manufacturer: Yes
      Dec 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
      Have lost my cd for setup on LexMart x5470.
      This is a link to Lexmark for your X5470 drivers....please select from the drop down lists at the bottom of page whether you are using Mac platform or Windows platform. Then choose which operating system within to download appropriate driver.
      http://support.lexmark.com/index?segment=DOWNLOAD&userlocale=EN_US&locale=en&productCode=LEXMARK_X5470&page=recommendedDownloads#3
      And here is a link to setup guide.
      http://www.lexmark.com/publications/pdfs/2007/5400/setup-sheet-en-es.pdf
      And your users guide.
      http://www.lexmark.com/publications/pdfs/2007/5400/v3421438_en.pdf
      Nov 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
      X5470 lexmark/missing disk
      click here
      select your operating system from this link and download driver .
      Let me know if you need more assistanse.
      Thanks.
      Sep 13, 2009 | Computers & Internet
      Lexmark X5470 All-In-One InkJet Printer Logo
      61 people viewed this question
      Top Lexmark Office Equipment & Supplies Experts
      Ekse
      Muntejaya Ginting
      Muntejaya Ginting
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
