Toshiba e800 Pocket PC Logo
Posted on Jan 17, 2012
Toshiba Pocket PC e800 wifi issues
I tried all kinds of ways to connect my Toshiba e800 Pocket PC to my D-Link router via WiFi with no success. It connected and worked once for about 1 min but never again. any ideas? Its been updated to windows 2003 SE so is supposed to support WPA.
3 Related Answers
Anonymous
  • 903 Answers
  • Posted on Sep 08, 2005
SOURCE: Video playback windows media
Import your existing movie into Windows Movie Maker (WMM). If you wish, edit it. When you are ready to publish, WMM has pre-set compression settings for PDA. Once published, copy the file to your PDA memory card using a card reader or RAM using ActiveSync. Note that Windows Media 9 is buggy on VGD machines, and you may see your movie at 1/2 screen resolution you intend. There is no way to fix this. Instead, I recommend Beta Player as an alternative (and more powerful, if uglier) movie player. http://betaplayer.corecodec.org/download It is free. Download the Latest Stable Player.
Anonymous
  • 903 Answers
SOURCE: Pocket e800, Internet Explorer problem
The presumption that your Wifi Compact Flash Card work with Windows Mobile 2003 is higher than working with Windows Mobile 2002. The new Windows is supporting much more hardware than the old one.
casouzaj
CARLOS R SOUZA JR
  • 1118 Answers
  • Posted on Apr 25, 2010
SOURCE: i have this pocket pc and i wnat to know if i can
Unfortunately, I think you are out of luck here. As far as I know, the e350 is not Wi-Fi enabled. Besides, its SDIO interface seems to be kinda proprietary, i.e.it is a subset of the SDIO standards. I don't know any Wi-Fi SD cards which would work with it. If Wi-Fi connection is a must for you, I'm afraid you will have to switch to a new phone, which either has built in Wi-Fi, or, at least, has a fully featured SDIO interface.
Hope you are able to sort your problems out.
Regards, Carlos
Trying to connect hp printer to wrt150n
there are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
I am trying to connect my toshiba a15-5129 in my house it will not connect to broadband
Hi, we have two ways to connect to broadband, via wired or wireless, at the device manager please do check if the LAN drivers are enabled, if enabled, via wired connection, simply put the RJ45 jack from LAN port of your router to LAN port of your notebook, if configuration is already set in your Router LAN, it will just automatically connect. If connecting via wireless press wifi button to activate wifi connection then windows will pop for your access credentials. simply put the password for your connection once the name of the site displayed.
3answers
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
2answers
Internet access via bluetooth
I don't have a PDA, but I'm working much with Bluetooth in my Toshiba Notebook. So I found a interesting link from Toshiba about Bluetooth. Perhaps it helps you! http://aps.toshiba-tro.de/bluetooth/
2answers
E800 wifi with sd bluetooth card with emtec crux11/btgps
Many people here have reported issues with the default Windows Mobile 2003 Bluetooth stack (basically, it just doesn't work). What may be happening in your configuration is that the CF card software is installing another Bluetooth stack (e.g. Widcomm's). This would explain why everything works thereafter.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
