Whirlpool LEB6200 Electric Dryer Logo
Posted on Jan 17, 2012
Turns on wont heat up - Whirlpool LEB6200 Electric Dryer
Ducane 2hp13l24p-1a My heat wont go off please
heat wont go off? what does that mean? turn the gas off and replace the valves if they're broken.
Oct 25, 2013 • Grilling
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
1994 lesabre heating and cooling
Probably a perished vacuum hose has collapsed or blocken, a bugga of a job replacing them. Check the ones at the engine first, it will be a small hose that disappeared throughthe firewall.
Terry
1helpful
Dryer heats up wont turn belt is fine
if you can't turn shaft by hand, motor sized or bearings(on both ends of shaft) shot.
Dryer will not heat but turns on and spins but no heat.
check breaker first it will run with the breaker tripped but it wont heat so turn off and on then check dryer for heat.dryers have a thermal fuse when they go bad it wont heat they are located on the element cage and are smaller than the thermostats.and if that is good then most likely element.but it usually helps to know what brand?
Mar 11, 2009 • Dryers
1helpful
Heating element wont turn off.What would cause that?
the heating elkemnt may have broken and is laying against the housing forthe heatere causing the "short"
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
