Question about Pool & Spa
My pacific hot tub has LOC on the display and i cant adjust the jets or temp. Is the display locked and how do i unlock it?
Posted by Mike Susinski on
TerryH
    Scholar:
  • 111 Answers
Mike,
Yes LOC is a standard topside lock code.
Try these common unlock codes,
Press & Hold Jet Button for 6 seconds
or
Press & Hold Temp Up & Temp down for 6 seconds.
Possibly your jet button is faulty i.e. it is broken internally or when it is pressed the button sticks in the on position and locks out the panel.
If those common codes don't work let me know which brand/topside control your spa has and I will get a more specific answer.
Posted on Jan 17, 2012
2 Related Answers
amanforallre
  • 77 Answers
SOURCE: QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Posted on Apr 22, 2009
thepool
thepool
  • 78 Answers
SOURCE: I have LOC on the control panel and I am not able
To Unlock Main Control Panel: Press DISPLAY, MODE, and DOWN buttons within five seconds. The “lock” symbol will disappear. All buttons are now active.
Posted on Apr 23, 2010
I have a coleman emerald 455 hot tub and I have managed to lock the electronic control panel. How do I unlock?
press program and then mode, it will display "0" and will be unlocked. u locked it by pressing program twice
Nov 05, 2010 | Pool & Spa
Spa went over set temperature with loc message
How far over the set temperature did the hot tub go?
A hot tub may sometimes exceed the set temperature slightly especially if it's well insulated and has been on a long filtration cycle.
'Loc' usually means that the keyad is locked or partially locked. Check your quick reference guide and it will tell you how to remove the keypad lock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 05, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Sep 17, 2009 | Pool & Spa
Jets stuf off on their own after about 20 - 30 minutes
This is normal for jets on hot tubs/whirlpools for the jets to shut off after 20 minutes. This is a safety feature to prevent overheating of the water. When jets are running, the hot tubs are constantly heating and can elevate to dangerously high temperatures excess of 110 degrees causing scalds that you would not even know are happening. Your body temperature acclimates to the climbing temps and you dont realize it is that hot. It also helps prevent you from falling asleep and not paying attention to the temps in the tubs. Sorry, but I think you are going to have to restart the jets after each cycle. It is a safety feature that can't be bypassed or circumvented. Good luck and happy tubbing
Dave K
Aug 29, 2009 | Home
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Lighting the oven
Control Lockout (on some models)
Your control will allow you to lock out the
touch pads so they cannot be activated when
touched or cleaning the glass panel.
To lock the controls:
Touch the 9 and 0 touch pads at the
same time for 3 seconds until the
control beeps twice. The display will
show LOC continuously and the time
of day if not blacked out.
NOTE: All cooking and timing functions will be
cancelled when locking out the control.
To unlock the control, touch the
9 and 0 touch pads at the same time
for 3 seconds until the control beeps
twice, and LOC will be removed from
the display.
NOTE: Some models have a Control Lockout
pad. Touch and hold it for 3 seconds to
lock/unlock.
Gas/Control Lockout (on some models)
surface burners, oven burners and control
panel so they cannot be activated.
To lock/unlock the controls:
Turn all surface burners off.
Touch and hold the Gas/Control
Lockout pad for 3 seconds until the
display shows LOC ON.
To unlock the control, touch and hold the
Gas/Control Lockout pad for 3 seconds
until the display shows LOC OFF.
When this feature is on and the touch pads
are touched, the control will beep and the
display will show LOC ON.
 The control lockout mode affects all
controls. No controls will work when this
feature is activated.
 The adjustment will be retained in memory
after a power failure.
Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Pool & Spa Logo
3,001 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
Tom Chichester
Are you a Pool and Spa Expert? Answer questions, earn points and help others
