Haw i can open the board without damage
The Shure wireless mic that has the switches on the side is tricky to open. The first thing is to take the cover off the switches and do NOT lose the two buttons. To remove the plastic cover very CAREFULLY pry up with a knife point near the center from one side. There is a plastic tab at each end of the little plastic part that is easily broken. by prying at the center of one side these tabs are pulled in a little and will release. There is not much that is serviceable within the wireless part so it is kind of a moot point to open it. When installing the buttons back one has to align each before snapping the cover back on.
SOURCE: feedback
That is a great mic. It has a lot to do with the room your in and acoustics of it. If you are too close to your PA or monitor, it will also feedback. Lowering treble and reverb will also help.
SOURCE: shure sm58
Hi danny
There not that much to take apart on the sm58. On page 2 of the user manual there is a wiring diagram to reconnect wires. the grill wind filter part screws on. The socket on the bottom is secured with a screw.
I am more than happy to answer any other questions you may have about
it, please get back to me here, or use the ASK function to go straight
to me :) If you are still unsure, have problems, or we need to look at
the situation more deeply, then before you give a rating for this
advice, hit the ASK button
Thanks for using FixYa, If you consider the advice I have given you as
sound, a FixYa rating is a great reward for my efforts to help you.
Cheers.
regards
robotek
SOURCE: shure sm58 wireless mike, 9v battery connection flaky
Unscrew the wind screen and slide out inside component, be careful not to pull too hard and disconnect wiring. You may have to re-seal with a clear silicone gel afterwards.
SOURCE: shure sm58 mic does not have full power
You should consider a microphone with more power to get the volume you need. I can personally recommend the CAD C195 Cardoid Condensor microphone. It has great output. The only downsidefor most people is that they don't have phantom power. This is what gives the mic its boost. In order to get the most out of any micrphone, you need to have a preamp, an equilizer, and an output. The output is your PA system that drumbanger mentioned.
But since you are using a Peavey, here is my strong recommendation. Get a mini preamp, and hook it up to your Peavey. You can use a Behringer 2mic mixing board for your preamp. It's small, and it can sit right on top of the Peavey.
XENYX 1002
http://pro-audio.musiciansfriend.com/product/Behringer-Xenyx-502-Mixer?sku=631262
CAD C195
http://pro-audio.musiciansfriend.com/product/CAD-C195-Cardioid-Electret-Condenser-Microphone?sku=270775
The reason why I suggest the two-mic XENYX 802 and not the 1 channel 502, is that the 1 channel doesn't have phantom power.
In order to connect the XENYX to your Peavey, this is all you need. You can get one at radio shack for pretty cheap.
http://accessories.musiciansfriend.com/product/Mogami-Pure-Patch-RCA-to-14-Mono-HiDefinition-Patch-Cable?sku=339031
SOURCE: Trying to open my Shure sm58 beta
About half way up the body you will see a seam. The body with the cartridge and wind screen separates from the bottom half of the body at that juncture. You have to unscrew one from the other. You will see wires that have to be unsoldered. Make note of where they were soldered and do the same thing for both the mike with the dead cartridge and the mike with the good cartridge. Swap straight across and you're done. Hope this helps.
i have Shure sm58 Wireless and i want to open the capsule without damage how can i ?
