What is a bootable disc (bios) - Computers & Internet
Brian Sullivan
  • Computers & ... Master
  • 27,725 Answers
The BIOS is the basic instruction set that teaches the computer how to access disk drives keyboardisplay etc The BIOS is typically placed on a ROM chip in the computer hence the term ROM BIOS.
The ROM BIOS allows the computer to boot itself. The BIOS is required to boot the computer. Thus, if the BIOS is password protected the computer will not boot
(or you will not be able to enter or change the BIOS settings.)
using the arrows keys scroll to Advanced Bios Features change the first boot device to cd rom press escape the F10 save to cmos to restart
bootable disc being the installion cd
hope it helps
Posted on Apr 01, 2012
Get error message "no Bootable disc"
You need to check the BIOS settings to see if they've been changed. Easiest fix once you're in BIOS is to choose "default settings" and then reboot. If the settings are correct (choosing the internal hard drive as the primary boot device) and it still won't boot, your hard drive may have failed.
My lg netbook appear no bootable device how to solve it
Hello
There is some connection probelm with its hard disc and main board. Hard disc is the common bootable device to most of the computers. Just get ito its Bios setting window, by press and hold "Delete" button during boot up, and see whether the Bios do recogonize the hard disc. The bios must recogonise the hard disc. Check it.
If you want anymore assistance from me, be free to get me by Fixya. OK.
How to start and format a laptop
U have to boot off the disc which is going into your bios and going to boot devices and have it boot of disc if disc is a bootable disc u should get a message saying press any key to boot of disc.. If disc is not a boot disc it will tell u to put in a bootable disc
My e-machine w3410 gives me a disk boot error insert disk and hit enter what does that mean
You probably have a non-bootable disc in the CD drive - when the computer powers up, your BIOS's first boot device is probably the CD drive and since it has a non-bootable disc in it, it can't boot. Remove the disc and re-boot your computer.
How to install the os
You need a bootable CD or USB disc.
When booting press F12 this will give you the boot options, or change in the bios the boot drive order to USB or CD/DVD
Linux are free OS's
Windows OS disc's are bootable.
2answers
Laptop wont boot from cd/dvd drive, hard drive is cleasn, no viru
Hi usavahe.
Booting from CD should be possible.
1) When the laptop first starts to power up, repeatedly press the F12 key. This should bring you to a screen that lets you select the boot device.
2) For the Satellite, it may show icons across the bottom of the screen. You want the one that looks like a CD.
3) It should the start to boot from the Windows CD (if it is indeed a bootable disc) and you will see the message "press any key to boot from cd".
4) Press any key you want on the keyboard and the Windows CD installation process should begin
Hope that helps
2answers
Hi drifterk back again for another problem i need help with. okay after i reset the Bios to Optimized Defaults i cant seem to boot my windows 7 setup disc from restart it doesnt pick up any disc's in...
For that when you power up the computer press F1 or F2 or "del" then enter in bios.
Then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
then it boot with that disk.
Let me know if you need further assistance.
Thanks for using FixYa.
I have an acer extensa 2305wlmi....i have 3 discs how do i reformat my computer backto factory one says disc1 bootable the others say disc1 and disc 2
The disc1 bootable will be the one you start with. Place the disc in the drive and then power on the computer. If the computer doesn't boot from that disc and instead boots to the old operating system, you'll need to get into the BIOS and make sure that the CD/DVD drive is set to bootable and that the priority is set higher than the hard drive.
2answers
DVD not detect at bios. why
if you press enter or space when you have an item highlighted does it not give you the option to add the dvd / cd ?
On some bioses it is there its just that its been disabled as an extra boot device to speed things up so that its not always trying to read or find a cd to boot from so if you press the key it requests you to ( near the bottom of the screen when you are in the bootable devices section ) it will explain how to alter or add them. If you follow the instructions you should be able to add it as a bootable device
If its not detecting any discs in the drive whilst in the bios thats because you need to save the settings in the bios to boot from the cd / dvd and the disc ( cd or dvd ) has to be made bootable and then once the bootable disc is in the cd / dvd drive and you have saved the settings in the bios and restarted it should boot from the disc thats in there.
If you need to make a disc bootable you can either use nlite or you can get guides on how to make a disc bootable if you search google.
Your operating disc and a linux disc(s) are all bootable
LG CD Rom Drive CRN-8241B(ABT)
hi Rich24 this is is nichu
first of all check whether the cd rom is connected properly to the hard disc and the mother board.
then follow these steps
in the bios set up
enter into bootable devices
set the first bootable device as -CD Rom
2nd bootable device as -hard disc
this must solve your problem
Computers & Internet Logo
Ekse
