Question about Palm LifeDrive Handheld
Moved PDA from one XP desktop to another. Loaded the PDA software on new computer and attempted a hotsync. PDA would not recognize new location. In an attempt to change, PDA ask for my password. I never loaded a password in the original setup. Therefore, I am unable to hotsync and update an expensive software application
SOURCE: Lost all contacts, memos, tasks, after LifeDrive Update 1.0
Well, I still don't know what happened, but things seem to be fixed. Just in case anyone else runs into this problem, here's what happened: Initial problem (recap): - on first HotSync after setting Quick Install to install the LifeDrive Update 1.0, the log showed the following error messages: Handheld Tasks application database version not supported. Handheld Notes application database version not supported. (Update 1.0 was installed successfully.) - after HotSync, all contacts, calendar data, tasks, and memos (i.e. all data synchronized with Outlook) were gone from the LifeDrive - subsequent HotSyncs produced the same error messages and did not restore data. Next day: - fresh HotSync synchonized other data, but not Outook data, HOWEVER - no error messages appeared this time (don't know what changed - neither PC nor handheld had been rebooted in the mean time) - used HotSync setup in Palm Desktop to set Desktop to overwrite Handheld for all Outlook data - it worked. Outlook data restored on Handheld. I don't understand what happened, but at least it was easier than doing a hard reset and then restoring everything.
Posted on Sep 12, 2005
SOURCE: PalmOne LifeDrive OS Installation
palm os is a flash rom built into the device, the only way your going to be able to do this (which will risk the device itself and i highly recommend NOT doing) is if you can get your hands on a flash tool to flash the ROM with your version of pocket pc os. i have never seen it done, but there are rumors that a palm treo 670 has windows mobile 2003SE on it. i just wouldnt recommend doing it because you could and probably will make your device useless and therefore will have to replace it. anyway, i strongly recommend that you not to do this unless you are really good with computers.
Posted on Sep 15, 2005
SOURCE: My Lifedrive won't boot up
do not waste your money on a new battery - i have been down the same road i even replaced the hard drive and some of the internal board connector ribbons in the hope that i could avoid having to spend out on repair- the life drive is inherently de funked you are not alone many users if not all have or will have the same issue- i would suggest giving up on it and finding a suitable replacement maybe the TX- unless you love it that much and money is no object.
oh and do nt waste your time looking to palm for answers i have also been there and nothing they suggested worked.
Posted on Oct 25, 2007
SOURCE: Error 1316 - installation failure
Have you uninstalled the previous version of Palm
Desktop?
Do you have more than 1 profile on your computer? Sometimes
multiple profiles can make things difficult is software is installed logged in
as one and then you try to install/uninstall as another profile.
Are you
installing Palm desktop from a disk?
Try this file from palms site -
http://www.palm.com/us/support/downloads/windesk414e.html
Also,
take a look at this-
http://www.palm.com/cgi-bin/cso_kbURL.cgi?ID=17525
Posted on Jan 07, 2008
Seems the LifeDrive Micro Drive is the killer on these Palms. Mine did the same thing and after extensive online research I found that the micro drive can be replaced with a Compact Flash card which is much more reliable. Apparently there are only certain CF cards that work with the LifeDrive though. I have found at least one retailer that sells a compatible CF preloaded with the Lifedrive software. The route I took for repair was to send it out to a guy that advertises his service on eBay. You send in the LifeDrive, he diagnoses it for $5, and can install the CF card with software for $89 (he waives the $5 if you have him fix it). I am looking forward to getting mine back in permanent working order! Here is the link:
http://myworld.ebay.com/itsnothere/
Posted on May 13, 2008
Dec 13, 2009 | Palm LifeDrive Mobile Manager Handheld
Mar 14, 2008 | Computers & Internet
Mar 09, 2008 | Computers & Internet
Jun 19, 2009 | Palm LifeDrive Handheld
May 05, 2009 | Palm LifeDrive Mobile Manager Handheld
Dec 06, 2007 | Palm Tungsten E2 Handheld
Oct 14, 2007 | Palm LifeDrive Mobile Manager Handheld
Sep 13, 2005 | Handspring Visor Deluxe Handheld
Sep 07, 2005 | Handspring Visor Edge Handheld
Jan 16, 2018 | Palm LifeDrive Handheld
