Question about Lenovo ThinkPad T400 PC Notebook
My Lenovo ThinkPad not startup, only the status indicators plinking. So what will be the reason and solution?
I left the laptop working(burning cd) on a bed but when i came back after 1 hr i got it not working(shutoff) and i try to start up but not possible only its status indicator blinking/flashing (on/off). so, what you recommend me to get back my laptop or solve the problem. Thanks a head for your help
Posted by burax909 on
JonSnell Electronic
    Top Expert:
  • Lenovo Master
  • 31,185 Answers
As it was left with no ventilation underneath for the cooling fan, it has desoldered the GPU.
Motherboard replacement or GPU re ball required.
Posted on Jan 20, 2018
5 Related Answers
Nitin_Master
Nitin Bhatt
  • 846 Answers
SOURCE: sound goes on & off on lenovo Y410 laptop
Here are all the drivers u'll ever need for Ur Lenovo Y410
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html
Posted on Apr 12, 2009
Anonymous
  • 92 Answers
SOURCE: lenovo touch pad not working properly
Have you tried pressing the Fn + F8 keys? This combination is used to disable and enable the mouse pad.
Posted on May 27, 2009
Anonymous
  • 92 Answers
SOURCE: lenovo Y510 stuck on logo screen at startup
Your hard drive maybe failing. I would make a back up as soon as possible . Then I would do a dskchk, Here's how:
Double-click My Computer, and then right-click the hard disk that you want to check.
  1. Click Properties, and then click Tools.
  2. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  3. Use the following procedures:
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer? Click Yes to schedule the disk check, and then restart your computer to start the disk check. Please don't forget to rate this solution.
Posted on Jun 13, 2009
Anonymous
  • 691 Answers
SOURCE: Can't open DVD drive on Lenovo ThinkPad Tseries
Hello
Thank you for using
FixYa for your problem
there is a little hole that a paper clip will slot into, thus pressing the release catch inside
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 21, 2009
Anonymous
  • 14 Answers
SOURCE: Thinkpad T500 lenovo laptop will not start but bat...
  1. Shutdown laptop.
  2. Remove battery, other external peripherals connected, disconnect from ac adapter.
  3. Press and hold power button for 10 seconds to drain power.
  4. Restart laptop.
Posted on Jun 09, 2010
I have put in pattern and i forgot it how to open it
I'm going to assume your laptop is an IdeaPad, since you're referring to a touchscreen lock.
If you're running Windows (any version pretty much), you can try downloading the Ultimate Boot CD ( Ultimate Boot CD Download the UBCD ) and using the MS Windows password removal tool.
You'll have to burn the image file you download from the link above onto a CD or DVD, then boot from it on the IdeaPad(?) from which you are locked out.
Lenovo is just a different name for the same part of IBM that made the original ThinkPad notebooks, so if the UBCD doesn't work you might want to try looking for solutions in the Lenovo BIOS (accessed during POST by usually pressing F12 or Enter).
Again, assuming it's Windows you're using, you can always try the startup repair menu accessed by pressing F8 after POST.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
May 21, 2014 | Lenovo Computers & Internet
Lenovo r61 startup repair is not working
What were you doing before it happened?
Apr 15, 2014 | Lenovo ThinkPad R61 Notebook
Does my lenovo thinkpad T510 burn dvd
yes it can write to dvds as well
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 18, 2012 | Lenovo ThinkPad T510 (43142KU) PC Notebook
How can i get the cd driver for my thinkpad t42? i got the problem with the multimedia audio controller, pci and modem
If you can't find a CD, you can log on to lenovo website, look for your model, and get the software driver that you are looking for. download it on a USB stick, or burn it in a CD using other computer, then install it on your laptop. that's it.
Feb 01, 2011 | IBM ThinkPad T42 Laptop
Not able to read dvd's and able to read cd's model lenovo 510i (what is it?) T510i Thinkpad?
While I was not able to find that specific model of laptop, I was able to locate the CDRW Bay and based on my research this bay only supports the following models. Though it may look the same and even have the same interface, if it is not in the supported model list, it will not properly function.
Supported Media Types:
  • CD-ROM
  • CD-R
  • CD-RW
  • DVD-ROM
Compatible with:
  • IBM Lenovo ThinkPad R50
  • IBM Lenovo ThinkPad R50e
  • IBM Lenovo ThinkPad R50p
  • IBM Lenovo ThinkPad R51
  • IBM Lenovo ThinkPad R51e
  • IBM Lenovo ThinkPad R52
  • IBM Lenovo ThinkPad T40
  • IBM Lenovo ThinkPad T40p
  • IBM Lenovo ThinkPad T41
  • IBM Lenovo ThinkPad T41p
  • IBM Lenovo ThinkPad T42
  • IBM Lenovo ThinkPad T42p
  • IBM Lenovo ThinkPad T43
  • IBM Lenovo ThinkPad T43p
  • IBM Lenovo ThinkPad T60
  • IBM Lenovo ThinkPad T60p
  • IBM Lenovo ThinkPad X40 series (X series media slice or Ultrabase required)
  • IBM Lenovo ThinkPad X41 series (X series media slice or Ultrabase required)
  • IBM Lenovo ThinkPad T30, X30, X31, R40 series (2366, 2367, 2884, 2885, 2681, 2682, 2683, 2896, 2722, 2723, 2724, 2897, 2672, 2673 - when installed with the optional ThinkPad Slim Drive adapter for the UltraBay 2000 or X series UltraBase or Media Slice)
If you see your model in this list comment back and we can move forward with getting your issue resolved.
Good Luck,
NOLA Tech
Jan 29, 2010 | Lenovo (13N6769) CD-RW/DVD-ROM Combo Drive
Need an optical driver for my dvd/cd-rw lenovo
well it's possible that your cd-rom actually is just permanently malfunctioning, i've seen it numerous times (i repair pc's and laptops for a living) the driver should automatically load using windows. the only driver i can find for the optical drive is for dos and people using win 3.1
Nov 03, 2009 | Lenovo ThinkPad Z60m Notebook
Thinkpad T61 went dark abruptly after startup
Make system restore, or better reinstal vista from IBM image file, dont install any updates, go get windows 7 , and get rid out of vista.
Oct 31, 2009 | Lenovo ThinkPad T61 Notebook
Imb thinkpad t42 will not burn. please help
hi im josh in cebu phils. friend when it happens when you cannot burn your cd the problem centers on the software and device it self. the first thing to do is try to reinstall or install other burning program such as alcohol, nero, etc.try different programs.when it stilll occurs then the problem is you device.just replace it. Good luck
Mar 06, 2009 | IBM ThinkPad T42 Laptop
Help cannot get into my thinkpad labtop lenovo t61
Turn the computer on and then wait for the startup ThinkPad screen. then press the blue ThinkVantage button on the upper left of the keyboard. This should bring you to the rescue and recovery applications on the computer and help you diagnose and hopefully recover your system.
Mar 02, 2009 | Lenovo ThinkPad T61 Notebook
Lenovo ThinkPad T400  PC Notebook Logo
131 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
