Started receiving error message for cartridge and alignment. Cannot locate users maual or correct problem
SOURCE: Lexmark p6210
The error message indicates a scanner stall/jam. Here is the Fix: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:462:0:0&framed=&docid=ENUS24402&relevance=1 write back if it worked regards, Tom
SOURCE: my Lexmark is X6100 Series - Cartridge Error 50C consult user guide
The cartridge has a short in it and needs to be exchanged for a non-defective one.
SOURCE: Refilled Cartridge
I have a Lexmark X7170 with the same type problem. Refilled without a prob for many times. The last time I couldn't use it after refill and bought a new cartridge which is already out of ink. I refilled it and after installing it I get a message that the cartridge is missing and the alignment won't work
BUT
Icalled my ink supplier to see if they knew of an anti refill device put in by Lexmark and they said that they had not heard this.. While talking I remembered that the previously I got a message while printing that the cartridge was missing but if I clicked OK the printer printed without a problem! So maybe yoy just need to skip the alignment, ignore the messages and try to print anyway. The last one I refilled is now working .
Another possibility is that after some number of refills the cartridges just quit and you need to occasionally purchase a new one - this I heard previously from my supplier
Good Luck
BL.
SOURCE: Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
SOURCE: Lexmark X4650
Here is how to align your print cartridges
Using the printer control panel:
1 Load plain Letter-size paper.
2 From the printer control panel, press tools , and then press ok.
3 Press the arrow buttons until Align Cartridges appears, and then press ok. An alignment page prints.
Using Windows
2 Do one of the following:
• In Windows Vista, click the windows globe (start button) .
• In Windows XP and earlier, click Start.
3 Click All Programs or Programs, and then select the printer program folder from the list.
4 From the printer folder, click Maintenance Align Cartridges.
5 Click Print.
6 Follow the instructions on the computer screen.
Using Macintosh
2 From the Finder desktop, double-click the printer folder.
3 Double-click the printer utility icon.
4 From the Maintenance tab, click Print Alignment Page.
5 Follow the instructions on the computer screen.
If you aligned the cartridges to improve print
1.
Make sure the printer is on.
2.
Open the printer cover. The print cartridge carrier moves and stops at the
loading position, unless the All-in-One is busy.
3.
Remove both cartridges from the carrier. Check the encoder strip (transparent strip behind the cartridge carrier) and make sure it is not unseated from its position.
4.
Close the printer cover.
5.
Unplug and re-plug the printer into the power outlet to reset it.
6.
When the printer turns on, check for any errors. If alignment error is displayed on the screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
7.
Close the printer cover and check for any errors.
8.
If no error appears, reinsert the other cartridge. Close the printer cover.
9.
Replace whichever cartridge is causing the error to appear with a new
cartridge. You can also try to
insert a different known working cartridge to determine if the other is faulty.
If problem continues,
