Lost the cd to install it
SOURCE: Logitech cordless desktop ex110
They should have an on/off switch on the underside that you can use to switch on/off...
SOURCE: MX 3200 Cordless Laser Keyboard - Logitech
Press the FN key and *at the same time* press the F10 key for 1 second.
The first part of the time should start to flash.
Use the up / down keys to change the hour, then press TAB. The minute figs. should now flash. Use up/down to change the minutes and press TAB.. do the same with the date and month etc, you can also set 12h or 24h clock.
When you are finished press ENTER.
SOURCE: location of the channel/connect button
ook at the side on the right of the keyboard just beneath the grey area. Its a round grey button with no labelling. Press the connect button on the IR module or the itouch icon on your system tray then press this button.
SOURCE: Unable to connect Logitech cordless keyboard
Of course you know to press the connection button on the receiver then on the keyboard. Since setPoint is recognizing the connection I wonder do the multimedia and function keys work? Do you have the the USB receiver for the KB/Mouse plugged into a hub or KVM switch? If so plug it directly into the back of the PC. See this KB http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9247
SOURCE: cordless keyboard not working.
there is a button under neath the recerver and the keyboard, hold the button under the recever and then hold the button under the keyboard
wait for a few secounds each time u hold this button then release and it should find it self then
