My CLP 300 is only 1 year old, but has started to persistently crumple the lower right hand side of my pages. I moved from a 20 lb weight paper to a 28 lb, but it still happens. Perhaps the right hand roller isn't clean? or it is overheating, causing the paper to crumple? Thanks for your help on this...
There is a foreign object in the paper feed path. It could be anything from a paper clip or staple through to an insect (or worse). It will definitely be on the side where the crumpling occurs. Try feeding a strip of card or thin flexible plastic backwards through the feed mechanism. A laminated sheet of paper can also be effective for this.
SOURCE: Samsung CLP-300 paper feed
Clean the feed roller.
Remove the paper tray, from the bottom there is a grey rubber semi wheel in the middle front of where the paper tray would be. Use a cloth with WD-40, brake cleaner, or lighter fluid to lightly wipe the rubber clean. Put the paper tray back in and it should print.
SOURCE: samsung 1340 crumpling copies as they print
how old is your printer if it is too old maybe you need to change the fusing unit
SOURCE: Striped line down right hand side of printout
the drum of the printer may be damaged. check if there's a noticeable line. replace if so
