This looks very much like my old M90... you pop out the battery, locate and unscrew the memory door, and then snap in the new memory. Then restart the laptop... if it beeps at your (this is called a beep code) then the BIOS doesn't recognize one or both of the sticks. Assuming all goes well it should prompt you and say something to the effect of 'amount of system memory has changed, press F1 to continue or F2 for bios'... go into BIOS and confirm its reading the new memory amount (2GB will say 2064). This model apparently only accepts 2 x 1GB sticks so hopefully you didn't order 2GB sticks... unless there's a BIOS update you can install the mobo won't recognize memory sticks greater than 1GB. Good luck.
These links will be very helpful... please rate me if this helps you:
http://www.ifixit.com/Guide/Installing-Dell-Inspiron-E1705-RAM/3987/1
This is the parent page for the E1705:
http://www.ifixit.com/Device/Dell_Inspiron_E1705
SOURCE: How do I install upgraded memory sticks?
Usually, you just remove a panel from the bottom of your laptop and there should be a couple of slots. all you then do is gently but firmly push you memory into the slot and when do,replace the panel and turn the computer on and all should be done
