Question about Plumbing
Blanco Supreme 533-U sink drain leaking at seal
The drain unit on our Blanco Supreme 533-U is leaking from around the rubbery seal between the sink and the plastic (white) drain unit (under sink). Is there a way of tightening up the seal between the sink drain and the plastic drain unit? I seem to have lost the Installation Instruction for the sink and drain unit, does anyone know if there is a copy online anywhere. Thanks for any help you can give. PS. I did see a simular question, and answer, on this site but that didn't refer to the plastic type drain fixing.
Posted by paulcun on
  • 1 more comment
  • paulcun Jan 16, 2012
    Thank you for your reply.
    But in the case of this Blanco sink, the only nut under the sink is the one that attaches the plastic down pipe to the plastic unit (basket/strainer?) under the sink. If this nut is removed the plastic unit is still attached to the sink: I can not see how this unit is removed so I can get to seal between the sink and the plastic unit (where it is leaking from). Any ideas?
  • martin parker
    martin parker Nov 30, 2013
    Paulcun, I apologise for repeating myself - i have also posted a coment to your similar post on another site, but thoght that I would ask here as well in case you don't see that one. Were you able to solve your problem? I have exactly the same problem. And the people who kindly replied to your question did not quite address te real problem - getting the basket off the sink.
  • Eamon
    Eamon Mar 06, 2014
    Hello Martin Parker. I now have the same problem. Did you manage to fix yours?
John McPherson
    Genius:
  • 1,212 Answers
The sink basket/strainer that fits into the large hole of the sink should have either a bead of silicone sealant applied to the sealing lip of the assembly or a ring of plumbers putty. Silicone will work very well if the mating flanges are clean and dry.
With the baket in place, the rubber seal goes between the large nut and the sink. A bead of silicon on this is optional on the sink side of that rubber seal. and the nut tightened down snug , forcing some of the silicone out fro beneath the mating flange and rubber seal. Tight enough so the basket is not free to move. Be it plastic or brass/metal, that order is the same, only a plastic nut is not tightened as tightly as a metal nut would be.
On the bottom of the drain basket assembly there is a nut, to retain a plastic or brass tail piece. The plastic tail piece will have a polyetheylene "flanged washer" for a seal to the bottom of the sink basket. If it is a brass tailpiece, a rubber seal and metal nut is used with "pipe dope"/thread sealing compound used on the threads of the metal nut. With the plastic nut, you can apply a few wraps of teflon tape to the threads of the drain basket, but is not required in most cases as the poly flanged washer will form the seal. The plastic nuts should not be tightened any more than hand tight.
beneath that, the rest of the drain assembly attaches. If plastic- no more than hand tight. if metal, only about 1/4 turn past hand tight. Metal nuts and parts should use rubber gaskets/seals and the plastic parts should only use the poly tapered/lip seals.
Posted on Jan 16, 2012
  • John McPherson Jan 16, 2012
    If your sink was cast as a single piece to include what is normally the sink basket, as part of the sink with only the 1 1/2 inch connection, there should be a thin flanged gasket between the flange of the thin pipe of the drain and the sink itself, and a rubber seal on the bottom side between the nut and the flange of the pipe. or alternately if you have a wide rubber flat gasket it should be between the flange of the drain pipe and the bottom of the sink. That stub of thin drain pipe sometimes does not get held tight due to how the nut was made and sometimes you need to use an O-ring to take up that space and support the flange..
    If that assembly of 2 seals in the first case is too thick to allow the nut to thread on the sink, an O-ring seal can be used in place of the rubber gasket to achieve the seal. 3 or 4 wraps of teflon tape or pipe sealing compound (pipe dope) should also be applied to the threads of the sink. That should address the leak.
    t cast with the sink, it may be siliconed in place, and does not have a nut on it. There are some the also clamp to the bottom of the sink The basket is nominally 4 inches across. if it leaks, the silicone seal was likely broken by later tightening of the nut or clamping assembly that rotated the basket. I am only adding this last part for benefit of someone who may have that setup inthe future.
What is the order for putting together a basket strainer for a blanco sink
Disassemble strainer apply a bead of silicone sealer around underside of strainer lip. Set strainer in place. Install rubber ring from underside of sink then cardboard or plastic ring then spin on threaded assembly hand tighten and then tightent 1/4 to 1/2 turn more . Remove any excess sealer. Install ptrap and drain piping and check for leaks tighten as necessary.
Hope this helps.
Bob
Jul 02, 2014 | Kindred 1135 Standard 3-1/2'' Basket...
Could an eroded drain cover gasket cause the dishwasher to leak from under the unit? It is not leaking onto the floor or under the sink, but it is leaking down into our basement along the concrete walls,...
I am inclined to not believe that is the issue. The gasket sits in a basin type of housing. If it was to be a failure, the water would flow into the drain hose and not outside the unit. The most common cause of leaks like this are the main gasket that seals the entire assembly to the tub.
Sep 07, 2013 | Whirlpool Dishwasher White Drain Cover...
What is the proper way to install a BLANCO sink strainer Kitchen Sink COD.100113 I believe is the code # Thank you
Hello, W/D here.
To install your strainer, you'll need some plumber's putty. The old one is removed by loosening the large ring on the underside and the strainer pulls out from the sink side. Once you are down to just the hole in the sink, you're ready to install the new strainer.
Get a portion of the plumber's putty in your hand about the size of a golf ball. divide it into two portions. Take one part, and roll it in between your hands, palms together and vertical, making a rope.
Take your rope, and place it around the sink hole. If you need more putty, roll the other portion in a similar fashion, and continue around the hole. You may need to overlap the rope putty where it's thin and at the ends to make sure that you get a good seal when you apply pressure the the basket. Place the strainer basket in the hole and press it down lightly, just enough to hold it in place. From under the sink, place the gaskets on the threads, followed by yjr large ring nut that will hold it all in place. Usually, there are two gaskets, a paper type, and a plastic type. Put the paper one on first, followed by the plastic, then the nut. Screw the nut down, applying some pressure to the strainer and plumber's putty. Adjust the strainer now, centering it in the depression in the bottom of the sink. Continue tightening the ring nut, pulling the strainer down into the sink, and squeezing the plumber's putty out, making a seal. Get it pretty snug, and wait a minute. The putty will continue to settle in the seal, and you will be able to tighten it some more after it does. Do this several times, and you'll end up with a good seal that will last. Take a regular screwdriver, and trace it around the strainer on the sink side to release the excess putty. You can ball it up, and press it back into the tub of putty, ready for the next time.
Best regards, --W/D--
Feb 09, 2011 | Blanco Sink Waste Strainer / Stopper...
My badger 5 plus 5/8 HP HD insinkerator is leaking from the bottom of the unit. It is dripping from the reset button and one other metal tab location. It is at least 10 years old. Can it be repared?
Sorry to read about your problem, I hope this helps you out.
sorry no it is rusted out, even if you could take apart, after 10 years 1/2 the parts will be rusted..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.
Thanks and good luck. you are looking around $90.00 for a new unit
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
The drain to my Blanco supreme 533 U sink has become loose and is clogged up. How do I remove the drain section to clean & reseal? There is no obvious screw holding it on.... Thank you!
The center drain is held in place from under the sink with a large nut threaded onto the drain. You'll need to remove this nut using a basin wrench. A pair of slip joint pliers may work if the nut is not corroded and turn easily. Of course you'll need to keep the drain from turning while you loosen the nut. Depending on how the drain lines are fitted you probably need to remove them also.
Nov 03, 2010 | Microwave Ovens
Leak from blanco aderlphi tap above sink line may be a washer required
this could be a leaking cartridge or more likely a likely a leaking o-ring that sits around the base and seals the joint between the spout and the base
Jul 01, 2010 | Blanco Plumbing
Deep scratches on blanco granite sink
The only way to fix scratshes and chips from a granite surface is to use a sander. You would be safer to have the company thet installed it, resurface it. They have the proper equipment.
Feb 17, 2009 | Blanco 511-620 supreme 2 One-Piece...
Plumbing Logo
1,501 people viewed this question
Top Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
