Question about Alpine CDM-7861 CD Player
I have an Alpine CDM-7854. I have hooked an M-Bus cable to the back of the unit in order to play an ipod. the source should change to aux but I do not know how to get the unit to change to it
How do you get the unit to be able to change to aux through the source button
Posted by Sean Druelinger on
1 Related Answer
Collegeboy
  • 6 Answers
SOURCE: Alpine CDM-7861 will not work with IPOD M-BUS cable attached.
Were you guys able to get this to work?????
Posted on Jul 05, 2010
Need wireing diagram for cdm-7854
Hello there,
Here's the Owners Manual PDF(includes wiring diagram) from Alpine's site:
http://vault.alpine-usa.com/products/documents/OM_CDM-7854.PDF
The Wiring Diagram is on 'document Page 16'... which is Page 18 of the pdf file.
Anyhow, the wiring diagram is in there.
I hope that works for you...
Mar 16, 2010 | Alpine CDM-7854
Ipod to alpine CDM-9821
Hello andrewbheber,
Your head unit is an Alpine "M-Bus" unit and has a proprietary connector for the AUX input. It requires a special cable from Alpine, the model KCM-123B..
Here's a link to the product. Click on the cable itself to see an image of what the connector on the back of your receiver looks like.
Hope this helps.
Sep 11, 2009 | Alpine CDM-9821 CD Player
an easy way would b 4 u 2 gent an fm tramsmitter thats the cheap route if its not on output 4 an ipod connection im pretty sure u can hook up ur amp the only wires that need 2 com from th in-das is a remote and ur rca the remote wire should b blue n u can get a headphone converter with rca ends but i doubt ur ipod will play out of ur amp.... let me know if this helps
Jun 23, 2009 | Alpine CDM-9821 CD Player
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Need a new plug for the back of the unit
you can purchase a replacement harness through me unit price would be $30.00 plus shipping ( depending on where you are located) email me if you are interested [email protected]
Mar 29, 2009 | Alpine CDM-7854
CDM 150 IPOD question
OK all you need is a 1/8 th inch stereo jack that goes out into two RCA cables RED and White (you can get this conector at any radio shack) now plug the red and white wires into the back of your gem sound unit AUX or TAPE..plug in your mp3 through headphone jack into 1/8 in plug....now turn on set switch to AUX OR TAPE DEPENDING on the one you plug into ..now play your mp3...make sure volume is up!
This should fix YA!
Dec 12, 2008 | Gem Sound CDM-150 Mixer
Remove cdm-7854
I was able to get the radio out just by pulling it out - there was no locks on my unit- thanks for your help.
Jun 21, 2008 | Alpine CDM-7854
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Alpine CDM-7861 CD Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
