Question about Timex Ironman Watches
How to set the DAY on the Timex Ironman Watch 839 HH
Watch with a stem. Need to reset the day of the week
5 Related Answers
Anonymous
SOURCE: Changing the DAY on this analog watch.
Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
I see that light bulb going off and you whispering "why, of course!"
Posted on Apr 03, 2008
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
Posted on Jun 08, 2009
Anonymous
  • 714 Answers
SOURCE: I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 10, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: how do i set date and day of week on timex indiglo
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please . .
Posted on Apr 20, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: For two days after I
Follow this link: http://assets.timex.com/user_guides/W148_M851/W148_M851_NA_EN.pdf Follow instructions and your watch should work properly.
Posted on Feb 28, 2011
How can I change the day on the watch (timex model T2E581). I am able to change the date and time ok, but not the day. Thanks for the help.
When you pull the stem out all the way (two clicks) it should set the time. Pulling the stem out one click you noticed sets the date, you turn it one way for the date and in the same postion you turn it the other way for the day. For some reason on some watches the day will stick, if that still happens you will need to turn the hands around and around until you get to the right day, then keeping in mind the 12 hour interval you are in... set the date and time. If the day still does not change then you need to return the watch if its new or send it to timex! Caution: when sending a watch to Timex sometimes they send back a different watch without asking so if its sentimental do NOT send it to Timex!! Hope this helps! have a great day!
Sep 19, 2011 | Timex T2E581 Watch for Men
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Sep 25, 2010 | Timex Ironman 53151 Wrist Watch
Timex Women's T5K188 Digital Ironman Pulse
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
May 13, 2010 | Timex 24101 Wrist Watch
How do I adjust the time and date on my Timex Expedition watch
Hi, the upper of the two watch stems is turned counter clockwise (looking at the stem) until the desired function (i.e., format, date, time, chrono, timer) appears. To set that function, pull the upper stem out and turn CW to advance & CCW to go back. Once hours & minutes are set, the stem can be pushed in upon a mark to start at zero seconds. For the day of the week, turn the upper stem CCW until date appears. Pull out the stem, to detents or positions, and this will allow the day to be adjusted.
Take care
Mar 25, 2010 | Timex Expedition47761 Wristwatch
How is the day of the week changed in a TIMEX Traditional analog watch. Pulling the stem out half way and rotating will only change the date. Rotating the time through multiple 24 hour periods will work,...
Setting the date is covered in the instructions which you can get instructions from the Timex web site "timex.com".
manual download"
Mar 15, 2010 | Timex Expedition47761 Wristwatch
How do you set Timex Triathlon Ironman watch?
Regards;
VOTIT
Jun 08, 2009 | Timex 27191 Wristwatch
Timex ironman triathlon - need directions to adjust time for day
Follow this link and download usars manual for your watch:
http://assets.timex.com/manuals/?timexBrand=core
Use ZOOM tool as the writings are tiny.
Do not forget to rate, please.
Mar 09, 2009 | Timex Sports Ironman Triathlon 100-Lap...
Change day
The trick is to turn the ring to the "Date" setting, Pull the stem out once for the Month and Date. Pull the stem out (hard, but gently) a second time for the Day of the week. Each pull will be confirmed by a 'beep. Be persistent and good luck.
Oct 15, 2007 | Timex Men's Black Reef Gear i-Control...
Watches Logo
649 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
STEVE SPAM REMOVER
Are you a Timex Watch Expert? Answer questions, earn points and help others
