Question about Kyocera Office Equipment & Supplies
Have error C6000 on kyocera taskalfa 180/220 - Kyocera Office Equipment & Supplies
Posted by amani on
Abdellah Ettaqui
    New Friend:
ERROR CALL SERVISE C6000 KYSERA
Posted on Nov 26, 2013
MIR AFZAL BOSTAN
  • 3 Answers
DEAR fRIENDS NEED HELP TO FIX MY COPIER KONICA MINOLTA BIZHUB PRO C500 ERROR CODE C45-02 PLZ.
TeleFax: 966-12-65o3104, Mobile No. 00966-502835548 / 00966-565339421 / 00966-540556951 e-mail :- [email protected]
Posted on Dec 15, 2013
Ks Omanakkuttan
A lot of thanks dear..........
Posted on Oct 15, 2013
5 Related Answers
shawn38
Shawn
  • 200 Answers
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
Anonymous
SOURCE: Kyocera Mita KM-C3232- Error Code C6000
The power source board may have created this problem and replacing the fuser may only be a temporary fix and after replacing the power source you may to replace the fuser again.
Posted on May 11, 2010
techf2
SOURCE: Free service manual with code
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email [email protected]
Especially interisuet off hibernation.
Posted on Aug 24, 2011
Anonymous
SOURCE: Have error: C6000 on Kyocera
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Posted on Sep 25, 2008
Anonymous
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
It is fuser error try resetting it by running mode 163, otherwise replace the fuser unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 26, 2016 | Copystar Kyocera Taskalfa 181 Copier
How to solve C6000 problem in Taskalfa 180/220?
Code C6000 Description Fuser heater break
The temperature does not reach 70 °C/ 158°F in 15 s before secondary stabilization.
Temperature rise of 1°C/1.8°F does not occur in 5 s before secondary stabilization (except during printing). Causes Poor contact in the fuser thermistor connector terminals.
Fuser thermistor installed incorrectly.
Fuser thermostat triggered.
Fuser heater installed incorrectly.
Broken fuser heater wire. Error Codes Kyocera Mita TASKalfa 180 Code C6000
Oct 28, 2015 | Office Equipment & Supplies
Have error C6000 on kyocera taskalfa 220. and no any button work.
You have to go to simulation 1087 -1087- then press 163 then execute and print baton and clear then 01 to Exit then OFF the machine and after 10 sec ON . the problem will be solved
May 23, 2015 | Kyocera Office Equipment & Supplies
1087 1087 then 163 reset it may prompt to turn off and on again,
if that does not reset copier replace the fuser assy
Mar 03, 2015 | Kyocera Office Equipment & Supplies
Problem in printing, when you run TCT me c6000
c6000 is a fuser error code try replacing the fuser
Apr 12, 2014 | Kyocera TASKalfa 180 Copier
Kyocera c6000 error
Fuser error try to reset it otherwise if it didnot work, change fuser unit
Nov 26, 2013 | Copystar Kyocera Taskalfa 181 Copier
C6000
http://fix-your-printer.blogspot.com/2012/05/solving-error-c6000-on-kyocera-mita.html see this
Feb 17, 2013 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
On the display it says call service c6000 and how to correct this error massage?
Hi
Error C6000 means Broken fixing heater wire. In fixing warm-up, the time to reach
50°C/122 °F exceeds 13.5 s, the time to reach 100°C/212 °F exceeds 10 s, the time to reach the primary stabilization exceeds 10 s or the time to reach the secondary stabilization exceeds 24 s. To resolve this try this reset procedure--
Turn off the copier by opening the top toner cover. Turn copier on, when you see message "close top cover" press "system menu" button. Scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time. Now scroll down to "maint mode", press "enter" then enter 163 press" enter " turn off copier then turn back on.
If this doesn't resolve your issue then you'll need to check whether heater M or S is installed correctly. If it is installed correctly then make sure that the heater M or S wire is not broken. Hope this helps...
Daniel
Oct 09, 2010 | Kyocera Office Equipment & Supplies
2,470 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
