Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
How do i charge my mad catz 60601 headset?
I took it out and set paired/set it to my ps3 properly. But when i go to charge it in either my computer USB port, or my ps3 USB port, there's no red light and it wont turn on anymore!!!
Posted by Andy Daley on
5 Related Answers
Anonymous
SOURCE: mad catz headset ps3
i can connect fine cos when im on setup it picks up the sound yet when i play cod 4 it does not pick up my voice yet it says that the headset is connected...its really annoying i only jus bought it
Posted on Apr 19, 2008
Anonymous
  • 13 Answers
SOURCE: new ps3 headset won' t work
like my headset was fully charged and i got grounded then it wouldnt work when i got my ps3 back if you have had the same problem shoot me a email at [email protected] if you have fixed it tell me out
Posted on Jun 16, 2009
Anonymous
SOURCE: my Mad Catz ps3 headset wont let me talk
i LOST INSTRUCTIONS AND DONT NO WHAT 2 DO
Posted on Jan 01, 2010
Anonymous
  • 5 Answers
SOURCE: Mad Catz PS3 Bluetooth® Headset Wireless
I was able to use myBluetooth Headset on Windows 7 by installing the drivers found in this link: http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Good luck! It took me about a week to find the solution.
Posted on Apr 27, 2010
award462
Anthony Ward
  • 397 Answers
SOURCE: need manual for mad catz ps3 bluetooth headset
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device, then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
Posted on May 06, 2010
Why wont my mad catz headset connect to my ps3. The PS3 gives me this error message 80010009.
Try to delete the headset from your bluettoth devices list on the PS3. Turn off the PS3 and then back on. Re-Pair your headset and see if you have the same error.
Hope it helps...
1helpful
Mine wont turn on
Hello, did you check the battery? Tu get the full charge, the headset red light must stay steady on. If you get it charged you can pair it: hold power button till the two leds blinks, now scan for bluetooth from PS3 and choose your mic setting. Other than that I'd call madcatz technical support. Good luck, Peter_Rei
Headset
If I've understood you question right, this headset's internal battery pack is rechargeable.
Cheers! Carlos
Mad Catz PS3 Bluetooth® Headset Wireless Headset can not hear
1helpful
I cant connect my headset
Have you charged headset via usb cable plugged into ps3...when charged press + hold silver telephone symbol...a blue pulse light should appear on headset..go to menu in ps3..to pair devise [headset] with Bluetooth.
2helpful
I have a mad catz head set for my ps3 and it's showing up on the ps3 but i cant talk to anyone.whats wrong?
The headset wouldn't connect so we deleted it. Then went back and tried to pair it again. And it wont flash blue and red, just blue.
What is the code to set your hed set up on the ps3 for the mad catz hed set
Pairing code is 0000 (four zeros).
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
4helpful
I can not get my mad catz bluetooth connected to my ps3.... I also do not have the instructions but i do have the pass code
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
Hope this helped.
1helpful
Make it work plz!
You need to have paired the headset. With the headset there should be instructions on how to pair it with the ps3. If not go to settings-> accessory settings-> manage bluetooth device->turn on the headset-> press scan-> and finally press the pair button(do not hold down). Finally choose the type of headset you have and enter the pass key. enjoy.
Top Mad Catz Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
