Open the front door/cover.Slightly push down the imaging unit which you want to replace.Pull the imaging unit outward, make sure first push it downward then pull it out towards yourself.Imaging unit will come out easily.After doing this, open up the new imaging unit.Remove its covering.Now put it straight, Green drum should be downward.Fit it to the machine from where you pulled out the old one.There are sliding at both side of imaging unit.make sure it sits perfectly in the machine gap.after inserting the imaging unit push it inward until it stops.If you heard a clicking sound then it means imaging unit has been fitted.
