Question about Sony PlayStation® 3 (80GB) Console
Netflix on playstation 3 wont let me sign in. It says invalid email or password. I know it is correct user id and password
Typically, this issue is resolved by logging into Netflix via PC and making sure the log in information matches the info on the PS3. Also, be aware that the standard package for Netflix allows only 2 devices to access Netflix from 1 account at the same time. For example, if you are watching Netflix on your PC in 1 room, and someone is watching it on a PS3, then you won't be able to access it from a Smart Phone or other devise, until 1 is disconnected from Netflix.
g" alt="11276523-pegq3jcpeyammqgc4cyp0cpv-4-0.png">
Posted on Sep 14, 2015
SOURCE: i try to sign into the ps3 server and it tells me
Don't worry. There is a huge problem occuring right across the board at this very moment with the PSN Network. Some consoles are not synching properly due to an internal clock error and causing problems exactly like you describe. It is expected to be resolved soon by Sony.
For a full breakdown please look at this FixYa Tip.
If the solution helps, please leave a vote for it. Thanks.
Posted on Mar 01, 2010
SOURCE: please help my ps3 accepts
This sometimes happens when the software becomes corrupt on the PS3. What I would do is back up all your game saves to a USB memory stick or memory card and then do the following to restore the PS3 software :
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later, then beep once more and turn off. Release the power button.
Step 3. Press and hold the power button again. It will beep once when you press it, again 5 seconds later and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then continue to the next step
Step 5. A menu will load. Select option 5, "Restore PS3 system". Accept anything you need to and wait for the PS3 to restart.
After this procedure, put all your backed up save games back on the PS3 and try signing in again.
This should cure your problem
Hope this helps and thank you for using FixYa
Posted on Aug 30, 2010
SOURCE: cant sign into playstation neywork
Hi the problem is not with your password so dont change any settings ok the problem is not your end everybody else is having the same problem, sony are having some down time at the minute to update their servers and software so just bare with them for a couple of hours and it will be back on shortly.
dont try changing any settings as the problem is their end not yours
let me know if you need further assistance or if it still not working in a couple of hours.
their are loads of people asking the same question in the last hour so you are not the only one, you could try going to the sony ps3 web site and check on their for any down time,
ill check myself now and post a message when i find something out ok
plz rate this solution as i have a whole page of unrated posts, thanks
i have just got through to sony and they are doing maintenance on the network so just bare with them and it should be back on shortly ok
i just found out the network is down for 12 hours some lucky people may sign in but will soon be cut off its down till 23:30pm GMT time as im in UK time here is now 19:28 so their is another 4 hours left of down time
Posted on Sep 21, 2010
Sep 13, 2014 | Sony Playstation 3 (PS3) Console
Jun 09, 2014 | Sony Playstation 3 (PS3) Console
Sep 08, 2013 | Netflix
Sep 13, 2011 | Sony Playstation 3 (PS3) Console
Jun 29, 2011 | Sony Playstation 3 (PS3) Console
Feb 23, 2011 | Sony Playstation 3 (PS3) Console
Click here to reset your password from a PS3™ system.
Click here to reset your password from the PSP system.
If you do not have this information, you will need to call
Consumer Services department and speak to a representative to reset your
password.
Consumer Services Department
800-345-SONY(7669)
Hours of Operation
Monday - Saturday 6:00 AM - 8:00 PM Pacific Time
Sunday 7:00 AM - 6:30 PM Pacific Time
IMPORTANT
If you have changed your password using a computer and had set your
PlayStation 3 or PSP system to automatically sign-in, the auto sign in
will fail. The PlayStation 3 or PSP system will prompt that the password
is invalid, at that point go to the sign in screen and enter the new
password you have created.
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Sep 22, 2010 | Sony Playstation 3 (PS3) Console
Aug 17, 2010 | Sony Playstation 3 (PS3) Console
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
2,211 people viewed this question
