Question about Lanier Audio Players & Recorders
How do I erase the tapes on a Lanier VW-210
How do I erase the tape on a Lanier VW-210 transcriber
John Nastase
    New Friend:
  • 16 Answers
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Posted on Dec 10, 2014
2 Related Answers
Dictation Mall
  • 145 Answers
SOURCE: Lanier VW 210 transcriber beeps like it is at the end of the tape
There is a sensor that detects tape movement. Unfortunately they do go bad and will probably need to be replaced.
Posted on Nov 28, 2008
Anonymous
  • 13 Answers
SOURCE: Lanier vw-210 dictaphone
It is not a problem at all! The VW-210 & 260 was designed to utilize a two-step erase procedure to prevent accidential erasing of tapes.
1.) Press & HOLD down the TEL button
2.) Immediately press & HOLD down Rewind button UNTIL erase function starts then quickly release both buttons.
Posted on Apr 15, 2009
I have a Lanier Transcriber Model V W-210. Today the fast forward and the reverse did not work. I could hear a motor sound, but the tape did not advance or reverse. The "listen" worked, as did...
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
Sep 20, 2011 | Lanier Audio Players & Recorders
Are you able to erase an tape on a Sony BM-147 transcriber?
No, this unit does not have an erase feature. You would need a magnetict tape eraser such as a BE10.
Jul 31, 2011 | Sony BM-147 Desktop Cassette Transcriber /...
I have a Lanier model VW 260 transcriber. 1) how do I erase old letters? and 2) does it have the auto rewind feature? (when I release the play pedal it goes back so many seconds) Thank you. Laura...
Hello Laura
Yes your unit has the option for erase Just hold down the REW and Telephone button at the same time make sure that you really want to erase the tape and the auto back space when you relase the foot pedal is the button located inside the front door they called Recall thats for adjusting how long you want to go back. thanks and good luck, if you ever need any type of accssesory please go to at www.tvps.com for large selection for professional Transcription units service and accessories http://www.tvps.com/Departments/Dictation-Accessories/Headsets/Cassette.aspx
Nov 24, 2010 | Lanier VW-160T
How do I erase tape on sony microcassett
Hold down the 'Erase' button and press the 'Rewind' button. It will erase the tapes as it rewinds.
Jun 07, 2010 | Sony BM-850T Desktop Cassette Transcriber...
Just started using Lanier model VW 260 transcriber for work. The counter display does not change. The top of the screen shows "Inst", "Length", "Unit No.", Total Units", and "Level". The only numbers it...
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Nov 13, 2009 | Lanier VW-160T
Nov 26, 2008 | Audio Players & Recorders
Aug 05, 2008 | Audio Players & Recorders
Lanier Transcriber unit will not play
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
Mar 02, 2008 | Lanier 260T Desktop Cassette Voice...
498 people viewed this question
Top Lanier Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
