Lite On LVC-9016G DVD Recorder/VCR Logo
Anonymous Posted on Jan 13, 2012
It doesn't recognize DVD types when we want to record from TV
Steve Si
Level 2:
Sergeant:
  • Expert 395 Answers
  • Posted on Jan 13, 2012
Steve Si
Expert
Level 2:
Sergeant:
Answers
395
Questions
0
Helped
195021
Points
821
Check you are using DVDR+ or DVDRW and that they are blank
How much does a DVD recorder cost? it doesn't have to be a fancy one.
I've seen some very basic DVD recorders for around $75, although prices can go up to $300.
If you just want it for very basic or infrequent use then you don't need to spend a lot of money. But look on the internet for buyers feedback if you find a make that you don't recognize.
Good luck and enjoy.
DVD recorder doesn't work
what is the problem, doesn't turn on or doesn't record .
Lg dvd recorder/vhs combo doesn't read dvds
Buy a DVD cleaning kit follow the instructions, sometimes brings it back to life. If no change! the assembly will need to be replaced,"not cost effective" cheaper to replace.
Hello, I have prblem regarding recorder DVD Pioneer DVR K16, The recorder doesn`t recognize DVD +R 8,5 GB. In cant find new drive. Currently I have 2001-07-01 ver.5.1.2535.0
Hi rafikuss
It is required to use a cable corresponding to U-ATA66 (80-wire conductor cable).
If this isn' t the cause , test with other manufacturer's dvd's .
Hope this helps ,
Best rergards ,
fanaudi .
NO d1 SC After Loading DVD What does it mean?
It actually should be read as "No Disc", as in it does not recognize the DVD you have inserted. There are DVD+R & DVD-R Your recorder may only recognize one type.
Cannot record from tv to DVD Can play pre recordecdvd's
You cannot record from the TV as the TV doesn't give an output to the DVD Recorder.
You can only record onto DVDs from an external source such as Freeview, Cable or Satellite Box.
3helpful
When I put a DVD-R into the DVD-R 155 recorder to copy a TV program after a few minutes of the blue disc at spinning at the top right of my TV screen the disc is ejected with the message 'disc cannot be...
This is a Samsung DVD recorder - I've had the exact same problem - By the way, don't you mean "this disc cannot be recorded" ? These DVD recorders are known to reject certain type of discs.
* Have you updated your Samsung with the latest firmware ?
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=dvdplayers&subtype=recordable&model_nm=DVD-R155&disp_nm=DVD-R155&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=03010300&model_cd=&menu=download
Follow the instructions carefuly and please understand the risks involved in flashing your drive - Do not interrupt the process, it can take long.
* here are the brands of DVD-R I have used successfuly with this recorder int he past:
Taiyo Yuiden DVD-R 4x / 8x (the optical drives used in those recorders are outdated, their writing strategies are never up to date and may not recognize some type of discs)
Maxell DVD-R 4x / 8x
Verbatim DVD-R 4x / 8x
Try another blank disc - maybe it will accept it - if it keeps rejecting all your blank DVD-R no matter what brand, you have a bad drive inside your recorder - the samsung recorders are **** - I have ever since gotten rid of that piece of **** and now use a Sony HDR-780 HDD/DVD recorder, uses pioneer components and is great !
Avoid those lens cleaners - they can do more harm than good!
I hope this helps.
Try different brands of DVD-R, avoid the cheap generic **** - drives like best Taiyo Yuden & Verbatim media id codes - they should recognize Maxells, verbatims, sony, taiyo yuden, ritek. if it keeps spitting out all discs you use, you have a defective unit. The latest firmware on that drive should also help !
Good luck :)
Won't recognize Sony DVD+R DVD.
Maek sure the recorder does not require the DVD - Type disk
Top Lite On Televison & Video Experts
Ngoro
ADMIN Eric
ADMIN Eric
August Brown
August Brown
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
