GPS Logo
Anonymous Posted on Mar 16, 2017
My Tomtom XL350 was working fine, plugged into the car charger. Suddenly, it just turned off and now appears dead. It is unresponsive to its reset button, connecting to a computer via USB or chargin
1. Working normally, plugged in to the car charger/traffic receiver. 2. Screen went black (presumably turning off) 3. Attempted charging in the car makes no difference. 4. Attempted charging on a computer via USB makes no difference. 5. Attempted charging with a 2 ampere capable wall USB charger makes no difference. 6. Pressing reset on the bottom for 10 or 15 seconds makes no difference. 7. Pressing and holding the power switch for up to 30 seconds makes no difference. 8. There appear not to be any LEDs except the green one on the car plug that does glow when it's plugged into the car. 9. No signs of life. 10. The device was purchased at Best Buy in the US in summer, 2010. 11. I assume it's just a latent defect that has presented itself conveniently (for Tomtom) a few months after the warranty expired.
Deepika Balla
Level 2:
Scholar:
  • Expert 98 Answers
  • Posted on Mar 16, 2017
Deepika Balla
Expert
Level 2:
Scholar:
Answers
98
Questions
Helped
53332
Points
282
Https://www.tomtomforums.com > TomTom Support > General TomTom Discussion
5 Related Answers
A
Anonymous
  • Posted on Mar 13, 2008
SOURCE: GPS Won't Turn On
My 510 was doing the exact same thing.
I called customer support and they helped me get it working again.
866-486-6866 is the number but here is what they had me do.
I had to push down the reset button for 15 seconds (the reset is in a small cut out near where you plug in the charger on the bottom.you will need to use a pin and you will feel the pin push in the button if you have it in the right spot.)
Then release the reset and hold down the power button for 10-15 seconds. the screen should come right back on.
If you need more help I suggest calling the 866# they are very helpful.
A
Anonymous
  • Posted on Apr 01, 2008
SOURCE: Tomtom one not poweringup
Lofty same just happened to me, following great deal of searching, my conclusion is that over voltage has fried regulator chip in tomtom, the reason you have green light is because at different part of power board. Approx repair cost if damage is not too bad (50% cannot be repaired) is £70.
TOMTOM will have a look for nothing, and give you a quote, if don;t want to proceed they will send it back for free also.
Good luck.
Anonymous
  • 124 Answers
  • Posted on Jan 27, 2009
SOURCE: tom tom one v1 Loose power connector
If the problem exists both when you use the vehicle power connector and the usb cable to your computer, then you have to assume that the problem is with the socket on the One. If it's still in warranty, I would send it back to Tom Tom for repair. Contact customer support for repair information.
The link is as follows:
www.tomtom.com
Anonymous
  • 171 Answers
  • Posted on May 12, 2009
SOURCE: My Tomtom XL won't turn on. No reset button apparent
The reset button is on the bottom of your device. On my older model XL it is just above the sd card slot. If you have the newer model XL 330 then you have to hold down the on/off switch for 20 seconds to do a reboot. If you have not used it in a while let it charge for 30 monutes before doing a reset.
Hope this helps
Anonymous
  • Posted on Aug 16, 2009
SOURCE: Tomtom 720GO wont turn on
The problem was solved as described in my posting of Aug.15,2009
2answers
My TomTom,VIA 280 has suddenly stopped working. It is barely 2 years old. It will not power up
let it sit on the charger over night, check the charger on another device too.
Dec 08, 2014 • Tomtom GPS
Tomtom GPS does not turn on
HELLO!!
Charger gets very hot means the problem lies with charger which is not supplying the power to the system ... Try changing the charger ... and the charger wont cost u more than 15$
CLICK HERE TO BUY
GUD LUCK!!!
I plugged the system in, the screen would not come on
Hi.
First check the charger connection. If an alternative charger is available test different chargers.
If the Tomtom is starting, then try first resetting your TomTom.
To reset the TomTom follow the instructions on TomTom website, clicking here: TomTom, portable GPS car navigation systems - Factory reset .
If the Nav is still freezing or is dead after reset, then there is an internal fault.
In both situations the alternatives are going to a TomTom shop or calling the TomTom service number listed on manual and following the instructions given by their representatives.
If the unit is completely dead, as a first thing better going to a TomTom shop and asking to test a different charger.
The charger can also be tested at home using a multimeter on charger connector.
Regards.
2answers
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
1helpful
New Motorola SLVR is suddenly unresponsive, won't turn on
Try to replace the battery and if the unit is still under warranty advise the store to replace the battery.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
2helpful
GPS Won't Turn On
dude check it the car charger really isnt a chargers. what! i kno i kno. the '' proper" way of chargin ur battery is thru the computer or u can purchase a a/c to usb adapter and charge it on the wall but the car charger is a trickle charge as long as the green light is coming on that means that there is power going to it and support is going to just tell ur charge the batter the right way over and over again try charging on the computer for about four hrs then see whats up if its still not working then call tech support and make sure u tell them that u tried charging it on the computer for four hrs
TOMTOM RIDER V2
Internally , the Rider is very similar to other tomtom models . From what you describe it sounds like your charger has gone faulty ( quite common ) . There is a sensing wire that goes from the charger to the plug tip to check the voltage is at 5v . If this sense wire becomes detached or broken then the charger will increase the voltage and unfortunalely , in turn fries 2 chips inside your TomTom . ( these are numbers U24 and U25 in most tomtoms ) . Its not possible for a standard electronics technician to repair these as it need someone experienced with these tiny components and also requires use of special tools and soldering techniques. You will have to have it repaired by either TomTom or a suitable TomTom repair centre . Even then , if the blown chips have got really hot then it's possible they have burnt the circuit board tracks and in this case a repair isn't possible. Throw the existing charger away as if you do get it repaired plugging that one in could easily cause your TomTom to blow again. You can check the voltage output of your charger using a multimeter which would probably confirm what I say above . Sorry to be barer of bad news.... Good Luck
2answers
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
9helpful
8answers
Tom Tom One Doesn't Turn on
in that case you will have to take off 4 screws on back the navigation system
easily take the back piece apart and unplug the battery wait couple a seconds then plug it back
it should work
60helpful
19answers
GPS Won't Turn On
Amazing what reading through the support page at TOMTOM reveals... I have the XL so no SD card to remove, but the support page explains that a hard reset by holding the power button takes 15 SECONDS. That's actually a really long time if you watch a clock. I pressed it and waited it out, and it worked. Powered right up. Not sure if I lost all my favorites and stuff but I have them backed up using TomTom Home anyway....
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
