1998 Plymouth Voyager Logo
Posted on Oct 12, 2008
Replace light blub in the infromation center on dash
Replace light blub in the information center on dash
Anonymous
Level 1:
  • Contributor 23 Answers
  • Posted on Feb 16, 2009
Anonymous
Contributor
Level 1:
Answers
23
Questions
Helped
8432
Points
34
After disassembly of dash and unit is away from dahboard enough to see. you will see fiber optic wires that go into one cluster. the could be white or black. it has one light bulb in that cluster it will twist out for replacement.
3helpful
2answers
Black spots on information screen 2003 mdx. I have the black spot that is over the compass on the non-navi infromation screen.
I am having the same issue in my 2001 MDX. It just appeard one day. Since then it has moved. It started out on the far right and is now in the center. ???
2answers
2005 altima Tried to replace dome light blub and fuse blew cannot find fuse also shifter will not go into gear after car is started.
Most often the battery cables as they connect to the battery get dirty and they can look clean and not make it so clean them anyway. If the car was jumped started wrong the main fuse can be blown and no power gets to the dash. Test light at the big power wire on the back of the altenator if its dead it's not going to start or light any of the dash lights either.
Please I will advice you take this vehicle for a scan and not to do a guess work on it.
Cheers.
Light on dash board nissan micra 01
if you dont have any light it could be a dash blub is out
james
G3Reseller.com
but i dont know would need more information
2answers
1998 Chevrolet Monte Carlo brake lights do not
check blubs if the center light works should be working side brake lights
2000 Pontiac Grand Am GT the clock won't light up anymore, everything else on dash is ok.
the blub for the clock might have blown out and you will have to replace it under the dash board...
Light blubs in Dashboard.
Hello scooterr1105,
If you have an all digital dash, then no, there is no light bulb to replace. It is a digital device, such as that of a calculator. While I am not familiar with these types of dashes, there may be some type of element in there that merely needs replaced. My Odemeter (milieage indicator) is lighted as such as well. I haven't had any issues with it as of yet, but I imagine there may be something to replace, rather than the whole part. I would call the manufacturer, or the dealer to research this more.
Thank you for choosing fixya.com. My apologize for not having a solution for you that would fix it.
carsandcomps
Guru, fixya.com
Oregon
Dash board lights out, need to replace blub. how do i do it???
only way to replace bulbs is to remove clocks
1990 Buick Lesabre Custom
You will need to include more information. !. Are you referring to the turn blub in the dash or the bluds mounted in the body of the car. If in the body of the car, you need to indicate whether it is front or rear.?
If the rear, open the trunk, and in the corner nearest the tail light you will see a cloth like material that can be pulled back, which will uncover the tail light assembly. From there you can remove the blub and holder by turning it to the left or right, pull it out and remove the blub.
Bill
Top Plymouth Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Plymouth Expert? Answer questions, earn points and help others
