Computers & Internet Logo
joseph Iyamu Posted on Jan 13, 2012
Serial number cubase sl 2.0 update
I need the serial number of cubase sl 2.0 update
2 Related Answers
Anonymous
  • 180 Answers
  • Posted on May 09, 2009
SOURCE: serial showing incorrect serial/ need tool 2 correct it
Contact your Hp auth agent and get them to reprogram the eprom - it is a program only supplied to auth Hp agents - called setconfig and it is a real pain to use.
glenn
Anonymous
  • 23 Answers
  • Posted on Sep 16, 2010
SOURCE: im trying to get the serial number for cubase sx
cool
Alguien tiene el numero de serie par cubase le 1.0.8.104
We only speak English on Fixya.
Does anyone have the serial number for cubase le 1.0.8.104
Cubase LE 1.0.8.104 serial number
Direct from Steinberg. Anything else is theft of copyright software.
How do I get activation code for Cubase LE?
Log in or create your Steinberg account here. Once logged in, click the Enter Download Access Code button, enter the Download Access Code, and then click Continue. Check your email inbox for a message from Steinberg. Included in the message will be your Cubase activation code.
May 26, 2021 En Espagnol
https://translate.google.ca/?sl=auto&tl=en&op=translate
412 / 5000
Translation results Directo de Steinberg. Cualquier otra cosa es robo de software con derechos de autor.¿C?mo obtengo el c?digo de activaci?n para Cubase LE?
Inicie sesi?n o cree su cuenta Steinberg aqu?. Una vez que haya iniciado sesi?n, haga clic en el bot?n Ingresar c?digo de acceso a la descarga, ingrese el C?digo de acceso a la descarga y luego haga clic en Continuar. Revise su bandeja de entrada de correo electr?nico para ver si hay un mensaje de Steinberg. Incluido en el mensaje estar? su c?digo de activaci?n de Cubase.
26 de mayo de 2021
Windows XP. eLicenser installed but will not run, comes up with an error message
The elicenser software installed by the product software may not not support your operating system, so the first thing to try is to update the elicenser software. Its available here:
Home elicenser net
1helpful
I NEED THE ELICENSER CODE FOR CUBASE STUDIO 4 MAC
Fixya will not give out any serial numbers, Activation Codes,
or Key Codes. It is illegal to pirate software
2answers
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
10helpful
2answers
How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
2answers
Top Steinberg Computers & Internet Experts
 Grubhead
Grubhead
Tesfay
Tesfay
Arcane Winzel...
Level 1 Expert
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
