Did this occur straight after changing out the battery, or after sitting with the new battery installed?
Have you checked the new batteries voltage and voltage under load, eg. (Voltage when headlights are on) could be a flat new battery.
Or could be load on the battery after key is turned off, something draining the battery overnight like a boot or interior light, radio left on ect.
Unlikely a short, or you would be in a world of burnt wires from the battery cables.
SOURCE: my 2006 hyundai sonata alarm keeps going off
One word:
Dealer.
Next time just disconnect the battery until you get it towed as this is a warranty item. I'll bet some wondered if this was a prank question like I did, right?
SOURCE: Hyundai Sonata 2003 Car starts then dies immediately :(
dear friend-it appeares that you have no feul pressure,check pressure,feul filter,feul system,
SOURCE: 2009 Hyundai Sonata-clicking noise at brake pedal,brakes applied
This is not a rich mans car so its normal. Your hearing the solinod that lets you take the car out of park after the brake is depressed so the car can't be put in gear unless the brake is on. If the noise bothers you the soliniod can be found and wrapped in insulation like a rich mans car them you can ride on feeling like a rich man too. ( the Beatles sang that a long time ago) and its still true today.
Testimonial: "Thanks. Dealer hasn't been helpful. I'll see how far I can go before I run out of patiencs."
SOURCE: Radio Reset for 2006 Hyundai Sonata
doubtful probably burnt up a component in radio thats why when jumping a vehicle u turn off all accessories so when something gets crossed it doesnt short it out usually will blow a couple of fuses
SOURCE: 2002 Hyundai Sonata "battery" light
The Alternator may not be charging at the proper level. If the car is running while you're trying to open the sunroof or turn on the defroster, then the battery light has nothing to do with those and they are separate problems. Have an ASE Certified mechanic check the charging system.
