Question about Dell Inspiron 4000 Notebook
Where is the hard drive on the dell inspiron n4010?
Getting error message Intel UNDI PXE-2.0 (build 083) check cabel connection PXE-M0F: Exiting Intel PXE ROM Operating system not found Where do I check to see if the hard drive is connected properly?
4 Related Answers
ajx13
Arjun Aukta
  • 110 Answers
SOURCE: my mini dell inspiration laptop sends me an error
This error comes up if the computer is not able to detect the hard drive. Power off the computer. Power it back on and tap the number 2 key 4 - 5 times at the Dell logo screen. This will take you to the system setp screen. Check if you see any thing listed next to solid state drive. If you dont see any thing try reseating the hard drive. Here are the steps to reseat the hard drive.. If you see an entry next to the solid state drive. You'll need to reinstall windows on the computer. If you have been shipped XP you will need an external CD drive to reinstall windows. If the system was sen with ubantu try to download it to a usb drive and boot off it.
Rate if useful.
Posted on Aug 08, 2009
Anonymous
  • 5 Answers
SOURCE: Problems with my inspiron 1501 details below
The problem your having could be the operating system is damange or the hard drive failed. Try to boot from a Windows XP or Vista CD to see if the drive is recognized.
Regards,
Posted on Sep 01, 2009
asingh1225
Amar Sondhi
  • 122 Answers
SOURCE: PXE-E61:MEDIA TEST FAILURE PXE-M0F:EXITING BROADCOME PXE
hello, sounds like bad hard drive. here is what you can try, go in to BIOS and reset it factory default save and exit, let the system start again go back in BIOS and check to see if you see your hard drive there, also this time disable Boot from Network option. seeif your system actually starts up... or you get "no operating system found", if you saw the HDD in BIOS and get no operating system found, you can try reinstalling windows.
if you still media test failure and it loops, you need a new hard drive.
let me know if it helps...
good luck
Amar Sondhi
Posted on Dec 03, 2009
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: upon start up my Dell
You computer is trying to boot from the LAN port (Ethernet).
Go into the BIOS by pressing either the F2 or the Del key. Check and make sure the hard drive is recognised by the system as with it saying "Operating system not found" does not sound good and could mean a hardware failure.
If it is seen by the BIOS check the boot order, change it to the HDD as the first boot device.
Regards.
Posted on Dec 15, 2010
How can I fix the error I am receiving at initial start up? See details section for Error and description of what has already been done to try and fix.
It sounds like the hard drive in your machine has failed. It uses a standard 2.5" SATA hard drive (Most likely 9.5mm thickness maximum, most are that.) Hopefully you have made a recovery CD set from the recovery partition on the drive.
Feb 24, 2015 | Dell 15.6" Inspiron 15R Laptop Computer...
How do I fix this error messageFor Athros PC/E Ethernetnet Controller v2.01.9 12/15/09 Check cable Connection! PXE-MOF:Exiting Intel PXE Rom No bootable device--insert boot disk and press any key Inte
That error comes up when the computer cannot find the hard drive or any other device to boot from so it looks for a network booting program and when it cannot find that, the error shows up. REPLACE YOUR HARD DISK,
Aug 01, 2014 | Toshiba Satellite Computers & Internet
Lenovo b460 laptop
it sounds like you have a hard drive failure hopefully you have restore cds and you can change hard drive and install your restore cds
Aug 18, 2013 | Computers & Internet
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
When I turn on my laptop it goes to a black screen that tells me... Intel UNDI, PXE-2.0 (build 083) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller...
based the message that you encounter, it may pertain to boot priority or to BIOS configuration.
My recommendation is for you to access and reset the BIOS settings on your computer.
May 10, 2011 | Acer Computers & Internet
Intel UNDI, PXE-2.0 (build 083) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v2'0.1.9(12/15/09) Check cable connection! PXE-M0F : Exiting Intel PXE ROM Operating...
That message is because the laptop is trying to boot through the network. You have to change the boot order in the BIOS, and put on first place the hard drive. Press the F2 key just before turning on the laptop. You should go to the bios program. On the bios, search for the Boot tab-move with the directional keys- you should see something like this: http://slackworld.berlios.de/2007/images_vmware/vm-bios-cdrom-boot.png. Press F5/F6 to move the hard drive on top. Then press F10 key, hit "Y" and then "enter". The laptop will reboot and it should boot through the hard drive-on which you have windows. If with hard drive on top, you still get that messsage, you will have to reinstall windows-it means that the files in the hard drive are corrupted- or replace the hard drive.
Jan 03, 2011 | Acer Aspire One PC Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
Dell Inspiron 4000 Notebook Logo
167 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
