Question about Activision Call of Duty 4 Modern Warfare for PlayStation 3
When i start iw3sp.exe not starting... each time its showing the message that plz insert correct dvd-rom...
Error in iw3sp is its showing plz insert correct dvd-rom... plz somebody help me...
Posted by sandy_lucky1 on
1 Related Answer
Anonymous
SOURCE: PLEASE INSERT THE CORRECT DVD-ROM,SELECT
when i enter spider-man 3 game it is saying error please insert the correct dvd-rom select ok and restart application
Posted on Nov 28, 2010
PLEASE INSERT THE CORRECT DVD-ROM,SELECT OK AND RESTART APPLICATION PLZ TELL ME WAT CAN I RAN CALL OFF DUTY GAME FACING THIS EARE MSG
Oct 09, 2010 | Activision Call of Duty for N-Gage
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
Brand new computer and i did not install the adobe it came with the computer Vista basic and i get the 1311 error message when i try to run adobe computer 1 day old !
no big problm if u comp is new r old...
When you try to install Adobe Acrobat 6, 7, 8, or 3D on Windows, the installer returns the error message "Error [1311, 1335 or 2350]. Source file not found: [drive name]:\ Adobe Acrobat [version]\data1.cab. Verify that the file exists and that you can access it." If you click Retry, the installer returns the error message "Cannot find the file Adobe Acrobat [version]\data1.cab."
Solution Perform one or more of the following solutions:
Solution 1: Check the Acrobat CD-ROM.
Make sure that the CD-ROM from which you are installing is free of dirt and debris. If necessary, clean the CD-ROM with a soft, lint-free cloth.
Solution 2: Temporarily disable anti-virus software, and then install Acrobat.
For instructions, see the documentation for the anti-virus software or contact the manufacturer.
Solution 3: Extract the compressed installation files, and then install Acrobat.
  1. Right-click the folder and choose Extract All.
  2. Follow the on-screen instructions.
  3. To install Acrobat, double-click the Setup.exe file located in the folder that contains the extracted files.
Solution 4: Uninstall the CD-ROM drive and let Windows redetect it, and then install Acrobat.
  1. Right-click My Computer and choose Properties.
  2. Click the Hardware tab, and then click Device Manager.
  3. Expand the DVD/CD-ROM drives section.
  4. Right-click each device listed under DVD/CD-ROM drives and choose Uninstall. Click OK to confirm.
  5. Close Device Manager and restart the computer.
  6. After Windows redetects the DVD/CD-ROM drive(s), insert the Acrobat CD into the CD-ROM drive and install Acrobat.
Solution 5: Install Acrobat from the desktop.
  1. Insert the Acrobat CD into the CD-ROM drive.
  2. Copy the Acrobat folder from the Acrobat CD to the Desktop.
  3. Double-click setup.exe in the Acrobat folder on the Desktop, and then follow the on-screen instructions to complete installation.
Additional Information Errors 1311, 1335, and 2350 occur when the Acrobat installer is unable to access the necessary files from the CD-ROM drive. These same errors may also occur if antivirus software interferes with an installation or if the installation files are compressed.
thank u sir,, if u feel i helped u, then plz vote/rate me with good marks..thank u!!
Jul 18, 2009 | Dell Inspiron 530s Desktop Computer...
Windows cannot start this hardware device because
try to uninstall the cd rom.... then restart your computer
Jun 29, 2009 | Sony DDU1642/C1 Internal DVD Drive
I cannot run my DVD Rom games in my PC after installation. It Displays a message " please insert CD/DVD rom and retry". please help.
That message means you have to insert the DVD into your DVD player.If you've already done that, the game isn't detecting it, and you will either have to buy a new DVD player, or use a crack. Cracks disable the DVD check in the game executables, thus rendering you able to play without a DVD in your PC.Go to one of these sites:gf.wiretarget.comwww.gamecopyworld.comand download the "fixed .exe" that corresponds with your version of the game.Backup the original .exe you are going to overwrite, you might need it later.When using cracks, it is generally advisable to first update the game to the latest version, and then downloading and using a crack.I hope this helps,Yannick.
Jun 10, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
CD DVD drives
try antoher cd-rom to see whether it's the optical drive or the pc>>>
May 25, 2009 | Tablets & eReaders
Error Message 'F:\ setup.exe is not a valid win32 application'
I uninstalled nitro. nitro for some reason blocks dvd roms from loading, and give a win 32 mesg.
Mar 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
C.p.u failor
hello, you cd rom drive is faulty thats why it restart your computer any time you insert a compact disc.
Dec 18, 2008 | Intel D915GAV Motherboard
I hate my computer!
No, this doesn't cost unless you sign up for Premium Assistance.
  1. Remove the disc from the drive.
  2. Look at the top of the disc (or game box). Verify whether it is a CDROM or DVD-ROM.
  3. If it is a DVD-ROM, verify the drive on your computer that you are inserting the disc into is capable of reading DVD-ROMs.
  4. Go to My Computer and verify which drive letter is the drive you'll be inserting the disc into.
  5. Insert the disc.
  6. Wait 20 seconds. If the disc doesn't automatically start up, go to step 7.
  7. Open My Computer and double click the drive containing the disc.
  8. If My Computer now shows the disc contents, find the most likely ".exe" file and run it.
Mar 06, 2008 | Computers & Internet
Startup
here try this ok?
richard from chicago and let me know if it works for you ?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00273968&cc=us&lc=en&dlc=en&product=311255
Issue After installing the all-in-one and restarting the computer, the following Generic Host Process for Win32 Services error message displays: Windows has shut down a process for Win32 services: Data Execution Prevention - Microsoft Windows To help protect your computer, Windows has closed this program. Solutions The following solutions should be tried in the order they are presented. If the first solution does not correct the issue, proceed to the next solution; if that solution does not correct the issue, proceed to the last solution. Solution one Uninstall and then reinstall the software using the following procedure:
  1. Uninstall the software by inserting the software CD that came with unit into the CD-ROM drive on the computer. NOTE: If the startup screen does not appear, double-click the My Computer icon, then double-click the CD-ROM icon where the all-in-one disc is inserted. Choose the Uninstall option. If the Uninstall option does not display, the software is not completely installed. Proceed to step 2.
  2. Install the software by inserting the software CD that came with unit into the CD-ROM drive on the computer. NOTE: If the startup screen does not appear, double-click the My Computer icon, and then double-click the CD-ROM icon, where the all-in-one disc is inserted. Choose the Install option.
  3. Run the Software Update from the HP Director and apply all patches.
Solution two
  1. Uninstall the all-in-one software using the CD that came with the unit, by following the steps in Solution one above.
  2. After the software is uninstalled, restart the computer.
  3. Install the all-in-one software by following the steps in Solution 1 above. After installation is complete, verify that the unit works correctly.
  4. Change the Windows Image Acquisition (WIA) service from Automatic to Manual by performing the following steps:
    1. Right-click My Computer , then select Manage . The Computer Management window opens.
    2. in the Computer Management window, click the plus ( + ) sign next to Services and Applications .
    3. In the list below Services and Applications , select Services .
    4. In the right-hand side of the window, right-click Windows Image Acquisition .
    5. Select Properties .
    6. Change Startup Type to Manual .
    7. Click OK .
    8. Close the Computer Management window.
  5. Add hpqtra08.exe to the Windows Firewall Exception list by performing the following steps:
    1. Click Start , then Control Panel . (Click Start , Settings , then Control Panel if you are in Classic Start menu mode).
    2. Click Security Center .
    3. Scroll to the bottom of the new window.
    4. Click Windows Firewall .
    5. Click the Exceptions tab.
    6. Click Add Program .
    7. Click Browse .
    8. Select C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe .
    9. Click OK .
    10. Click OK .
    11. Close all open windows.
    12. Restart the computer and verify that the unit works correctly.
Jun 12, 2007 | HP Officejet 5510 All-In-One Thermal...
Activision Call of Duty 4 Modern Warfare for PlayStation 3 Logo
174 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
