Computers & Internet Logo
Anonymous Posted on Jan 13, 2012
Is high CPU usage will make battery life reduction?
I found that some good application always take much CPU usage. when I use such an application, the CPU usage become so high and it reduce the battery life. Why? And will Magican will take high CPU usage of my Mac?
damneddle
Level 3:
President:
  • Master 1,607 Answers
  • Posted on Jan 13, 2012
damneddle
Master
Level 3:
President:
Answers
1607
Questions
Helped
336728
Points
4892
Anything that requires more activity from your CPU will shorten the battery charge. It is eating power. I am not sure about "Magician".
2answers
Outlook express freezes
There are many things that might cause your PC or any application in your PC like outlook express to run slowly or freeze or even restart at time and then. It could be a fragmented disk, fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; caused by an infection.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
So here is the best solution that I can suggest for you is to scan your
PC with a very strong antivirus, here is the link to get it.Its very good.
http://f1226ed7g6j0vsm6nlwdh440fx.hop.clickbank.net/?tid=DMWDH6W3
To clean up registry there is another very good application which will keep your PC registry out of trouble caused from spywares.
http://6d099feff2g50wdmmpgh0brrf1.hop.clickbank.net/?tid=DMWDH6W3
tip
How to Protect PC from Overheating?
Laptop over heating which is also known as Thermal Overload.This is mainly due to excess usage of CPU(More than 60%) for a long time.
To check CPU usage Right click on Task Bar>Select Start Task Manager>Performance.
or
Shortcut Ctrl+Shift+Esc
If your CPU usage is more than 50% you need to close some applications which are using 20++% CPU.
To check application which are using 20++% CPU
Right click on Task Bar>Select Start Task Manager> Processes
Search in this dialog box for programs which are using 30++% CPU
You need to close this application to prevent PC from over heating.Actually %age usage indicates load to CPU by the application.If load is to much CPU is to processes at faster speed which in turn increases temperature of CPU.
To close the program select the program,and select End Process.
If didn't found any program using 30++% CPU in this dialog box.
Select Show process from all users. and search in this dialog box and close the program.
Caution:some times your system also uses 30++% CPU inn some processes like anti virus scanning,at this if you closed the program your PC may shutdown.At this time you need to restart the PC.
This usually happens for out dated anti virus or incompatible programs.
There are some other factors like Graphics Properties and Graphic Memory,Display size, Processor type,etc.At this time its better top use a cooling pad.
Some program like camera drivers,Simulation softwares,games uses 50+% CPU.This is common these programs need to process large amount of data at short interval time which increases CPU usage but this is normal.
The processors properties are tested at 140*c so no need to worry.If the CPU exceeds the limited temperature PC will shuts down automatically,and after cooling you need to start the PC.
Thank you...:)
ANY SUGGESTIONS...?
on Feb 16, 2011 • Computers & Internet
Why pc is not shut down after clicking on shut diwn option
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good virus scanners that you can run to check your PC:
1helpful
2answers
Memory full while i'm browsing
before this happens open task manager (press ctrl alt delete simultaneously).
under performance tab see cpu usage and memory.
cpu usage should be about 2% normally.
memory should not be full.
if cpu usage seems high then a virus is trying this act or you have unwanted programs which you my end from startup.
second case is of some problem in ram
Seems my toshiba satellite lap-top is over heating, how do I get to the fan to clean it? Model number: psafgu-02k001 serial; x7253530q
If your fan is running OK, then it probably doesn't need cleaning.
I have a satellite A350 and it pumps out a LOT of heat but that doesn't mean it's overheating. It's more likely your CPU usage is very high, which makes it very hot.
Turn on the CPU Meter in the Windows sidebar and close all applications. Watch the CPU usage (the larger front meter) for about 20-30 seconds. If the AVERAGE level when running no other applications is over 40% or spiking up at 90 or 100% then you are probably running too much junk in the background, or you have a virus.
2answers
My Dell Latitude D620 runs slowly on ac power. The pc usage spikes to 100. Occassionally it will start running properly on ac power, but problem persists once unplugged or hibernates.
This sounds like a problem with your power management settings. On battery power, many of the "bells and whistles" futures such as the transparent task bar are turned off to save battery life. This greatly reduces your cpu usage, thus saving power. I would recommend changing the theme from Windows Aero to Windows Basic. This can be found by right-clicking on the desktop and selecting personalize. Good luck!
1helpful
Mac OS 10.5.7 high user account CPU usage
Hi.Maybe you don't let your notebook get the air that must take.Probably if you have it on your feet on bed the macbook cannot breathe.Check this software out if you need further information about your computer's hardware temperature.
http://www.almico.com/sfdownload.php.
2answers
DPH-50U driver using high DPCs
I had a similar problem on a pc i built. the culprit was my wireless card. i opened up the pc and moved the card from one pci slot to another. powered it on and it redetected mt card. my cpu usage went from 40-50% at idle to 0-5% depending. hope that helps
1helpful
CPU usage very high, mouse very slow man
hi,
you haven't mentioned whether your mouse started moving after you deleted the applications..
Anyway to lower your CPU usage, you can do the following...
1. Run 'msconfig' without the inverted comas in the run dialog box. ( start--> run )
2. Select the startup tab... you can disable all application at startup to load the system faster. or you can select the application that you thing is unnecessary. this needs a restart.
3. Next try to press Ctrl, Alt , Del at the ssame time to launch the task manager. First you will be seeing the application that is running. Go to the next tab that is the Processes tab. under this you will see all the processes that is running and utilsing how much resources . Below on the status bar of that window you will see the cpu usage... Now identify the processes that has the highest memory usage... right click and select end process tree. the process will be stopped. Remember not to end the explorer.exe process. Most resources is utilised by Anti-virus softwares like norton, also by web-browsing and graphics opertaions....
hope to get rated as fixya!!
regards
bzoy..
Motherboard & CPU temperatures
CPU usage generally depends upon what application(s) you are running. There are some apps that barely utilize the cpu, and there are others that are resource hogs that peg the CPU near 100%.
CPU temperature will also vary, depending on the load, and numerous other factors. For example, the ambient temp will affect the CPU temp - when it's cool in the room, the CPU temp will not be as high as if the room temp is warm/hot. Other factors include the type of HSF, the number of fans in the system, and the case itself, as some are better at dissipating heat than others.
So, to give you a better idea of what temp is normal for your setup we'd need much more info about the system. But for reference, 40 celcius is a pretty good CPU temp, particularly if that is under load.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
