Question about RCA Crf907 Compact Rf Modulator
Bought a ROKU XS needed a RCA CRF 907 TO CONNECT TO MY OLD SONY XBR 55' TV..DIDN'T HAVE ANYMOR
HOW TO HOOK UP RCA CRF 907 MODULATOR TO TV WOMEN ALONE IN WHEELCHAIR NEEDS YOUR HELP TRYING TO SET THIS UP TO SUBSCRIBE TO NETFLIX STREAMING..HOUSEBOUND!....I HOOKED UP THE ROKU XS TO THE CABLE BOX AND THE WIRED ROUTER. I DIDN'T HAVE 3 INPUT PLUGS OPEN IN THE TV AND WAS TOLD TO BUY THE RCA CRF 907 MODULATOR. I PLUGGED THE THREE WIRES RED/WHT/YELL INTO THE MODULATOR AND PLUGGED THE AC INTO ELECTRIC...WHAT KIND OF COAXIAL WIRERS DO I USE ON THE OTHER END OF THE MODULATOR AND WHAT DO I PLUG THEM INTO? IF TV WHERE? THANK YOU SO MUCH
Posted by MARILYN LISA on
Chop Dopeybloke
    New Friend:
  • 124 Answers
Hi, after a lot of searching I found all your bits but not too sure on the TV itself as it's not showing connections on the rear.
However as far as I can see, based on the device and your question, it looks like the standard old style coax goes from the CRF 907 TV OUT socket to your TV's ANT. IN socket.
I hope this helps.
Posted on May 14, 2017
5 Related Answers
MikeNJ1964
Mike Longo
  • 398 Answers
SOURCE: RCA 52" tv. model # D52W20
The silver box is called the TUNER. Call an RCA distributor, such as Union Electronics or Herman-Panson and order it by description by asking for the tuner for your model number. Have the location number on the board, just in case.
Posted on Sep 01, 2007
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
Anonymous
SOURCE: connection for digital signal box
You'll need a coax to twin lead transformer that you can buy from Radio Shack.
Posted on Jul 04, 2009
Duane Dahlman
SOURCE: Instructions to hook up a Thompsen/RCA model CFR940 video source selector with RF modulator
i need a diagram
Posted on Feb 02, 2012
richie46
  • 12962 Answers
SOURCE: Can i hook up converter box to tv with rca jacks because coaxial plug is broken thank you
Only if set has RCA inputs for video and audio.
Posted on Aug 11, 2016
How do get Netflix to my TV
It would help to know if you have a SMART TV"....
But in general...
subscribe to the service & stream away
or for "NOT-NET-CAPABLE" (not smart) TVs
One solution would be to buy a Roku box...plug it in
Subscribe... & stream away
Carnac the Magnificent
Feb 10, 2017 | Netflix
Will Netflix work on any TV?
You'll need a device that hosts the Netflix app. This might be a Smart Blu-ray player, or a media streaming box, or a Google Chromecast. I don't know about Charter Cable. Does their box have Apps. Is one of them Netflix?
As long as you have decent broadband speed, and an unlimited service, then running the Netflix app via a host device will work for you.
Sep 10, 2014 | Televison & Video
Hook Sony TV and DVD Blueray to Netflix
if you have an hdmi port in your tv and you pc and an hdmi cable you can connect that up. and view your pc screen on your tv.
Feb 17, 2014 | Computers & Internet
How do i access netflix on my tv
This tv does it have cabilities for the internet by itself?Yes,than just go into Neflix website subscribe and watch ur shows.Not,than must used a computer to acess the internet an subscribe to Netflex and used the tv as a hook up and used it as a computer monitor to watch ur Netflex shows.
Jun 13, 2011 | Samsung 46 LN46D550 LCD TV
We bought this tv because it was internet ready and were very excited to be able to watch Netflix instantly on the tv. We followed the steps necessary to set up the netflix on the tv and entered the...
did you sign up for netflix on a monthly basis, or was it just a trial. Maybe the fact you cant connect to netflix anymore is because your trial has ended and you will need to subscribe to it by paying a monthly fee
Apr 05, 2011 | LG 47LE5400 47 in. TV
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
Trying to hook up magnavox dvd recorder model mwr10d6 to du1901 tv will i need a rf modulator.
If you don't have the yellow, red and white RCA jacks on the set anywhere, an rf modulator would be the simplest way to go. Then all you will need to do is put the tv on ch3 or ch4 depending on what the modulator is set to.
Oct 18, 2009 | Durabrand DU1901 TV
RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Nov 08, 2007 | RCA F27242GY 27" TV
RCA Crf907 Compact Rf Modulator Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
