Question about SanDisk 2GB microSD Memory Card
I need aprogram from format my memory card - SanDisk 2GB microSD Memory Card
Posted by eslamayman on
Brian Sullivan
  • SanDisk Master
  • 27,725 Answers
If you mean you want to format your sd card
click start click on my computer you should see your sd drive
right click then select format
another way is to control panel administration tools computer management disk management right click on your sd drive select format
hope this helps
Posted on Jan 13, 2012
2answers
I can not formate my SD memory card it shows windows was unable to formate
You will need special formatting software from the disk maker. Windows XP will not normally format a sd memory card.
1helpful
2answers
My memory card show to format it when i attach it to my pc but after formatting i cant able to use it now what can i do
Soory dude very sorry to say that your card will never work again.
who said you to format the memory card with your pc. You doen't, every phone has a format opt for formatting the card. And in every phone's manual it is written that "Format your card with your phone option. Don't format with your PC It will pemanently damaged your card". So, formatting your card with pc will damage your card for forever.
Jun 16, 2011 • Cell Phones
7helpful
When iam opening memory card in nokia 3110c it is saying memory card not formatted operation failed.please guide me what to do
Hi, problem can solved.When a memory card says formatted operation failed,it means the memory has been affected with VIRUSin it,thats why it's not given you access to get into it.
What you will need to do is to format it.
You can use your phone to format the memory card by going to the option of the memory card and click on format memory card.
Also you can use a PC to format the memory card by using a memory card reader. insert the memory card inside the card reader and connect to your PC, click on my computer, you will seethe memory card icon displayed, right click on the mouse for options to come up, and click on format memory card and you done.
Note: When trying to format and it does not format the memory card, that means the VIRUS that affected the memory has damaged it totally, that means you will have to get a replacement memory card.
Thanks for using fixya....
1helpful
I cant see any photos which are there in memory card in the gallery.
If you cannot see the pictures on your phone, that is on the memory then you need to format it with the steps below but before that connect the memory card to your pc an save all data there first. when finished with the format replace them back to the phone
NOTE: Format the memory card if you forget the memory card password. The device will allow you to format and erase the memory card password without asking for the password during the formatting process.
To format the memory card:
1. Press Menu
2. Select Applications
3. Select Office
4. Select File Mgr.
5. Select Memory Card and press Options
6. Scroll to and select Memory Card Options
7. Scroll to and select Format
8. Select Yes
NOTE: Format the memory card if it intermittently malfunctions (e.g. errors, file corruptions)
The Formatting option will properly configure the memory card for use with the phone.
2helpful
Windows media player 11 dectets kingston 4G SD memeory card but will not allow to format it
To format the memory card you need to go to my computer,right click on the memory card icon and choose format that will format the memory card.
How to format a sd card sdhc card 4 gb
if your using it by phone you go on to phone setting and memory manager then format the memory card
but if your wanting to format by pc
you need to go on my computer and right click there should be a menu saying format ect you need the format.
but if there is not format
just click on the memory card the wipe everything off
9helpful
My Z740 won't format my memory card. When I turn
My Z740 won't format my memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message.
1helpful
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Memory card needs formatting.
take a look at your memory card to make sure it is not locked, then try formatting you memory card
1helpful
2answers
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
SanDisk 2GB microSD Memory Card Logo
Top SanDisk Electronics - Others Experts
k24674
Jax Planet
Jax Planet
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
