SOURCE: I accidentally blocked my cell
Select menu button and select initial setting, then scroll to call block and press select. You can now remove any call blocked numbers you want from this selection. This id the call block storage area.
SOURCE: kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
SOURCE: HOW DO I UNBLOCK A BLOCKED PHONE NUMBER
Too many variables to give you an exact sequence. Ours is *60 to set and *80 to cancel. It may also be #60. Sometimes, you can dial *60 and the voice will tell you how many you have on your list and how to add or delete numbers.
Carl
SOURCE: I have blocked a number
Contact your telephone company if you want it permanently corrected, or if you would, like dial *67 then your phone number.
