SIR>MAM there is NO hard drive on that machine it is a analog machine it is a very old Minolta Machine!!!! SO NO DRIVES>
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
SOURCE: Minolta ep1031 with a C 50 error
http://files.mail.ru/E3J8UV
Read service documentation EP 1035/1031
error C50Warming-up Failure
Faulty Fix Unit reasons:
- no contact or faulty lamp of the heating
- no contact or faulty thermistor
- no contact or faulty Fuse
- no contact or faulty controller of the direct current
The Repair is not simple and is required experienced master of the service, change the adjustments, clear instruction of the regulation of the check. Recommend to apply to service Vinolta Good luck
SOURCE: minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
SOURCE: I just replaced the toner cartridge in my Minolta
There is not awhole lot to do.. The toner bottle you put in was it a white or light blue? White is toner & light blue is developer. Developer is used by a tech to replace. It sounds like the copier is over toned. You are most likely going to have to have the developer replaced to solve the lose toner... Wish I could give you a easier solution.
SOURCE: minolta cspro ep1085 need to know if there is a
No there is no hard disk drive in the EP1085. This was an analog machine and as such had to provision for PC connectability, printing or scanning. Therefor no hard drive needed or offered.
Thank You for using Fixya!
WheatlandServices
Testimonial: "Thanks so much for the information about Minolta EP1085. The information was very helpful indeed. THANKS AGAIN!!! RAS"
