Amazon Kindle Wireless Reading Device Logo
Fiona Posted on Jan 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to use a kindle
What does it mean to turn wirleless on or off
Anonymous
Level 2:
Sergeant:
  • Expert 331 Answers
  • Posted on Jan 12, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
331
Questions
0
Helped
93067
Points
691
Go to the Kindle Support web page where you will find help information for Connecting with WiFi (Wireless networking) or WiFi Troubleshooting.
In essence, you turn the wireless connectivity on or off by using the Menu button on your Kindle then selecting the option to do this that is shown.
2answers
How do I connect Kindle to WiFi network?
It is so simple just connect the Kindle wifi with password. Sometime due to virus issue Kindle do not connect with the wifi For more you can ask for the Kindle Support Kindle Technical Support Registration 877 690 9305
My Kindle fire won't move past the start up "kindle fire" screen. what is wrong and how do I fix it?
Hello
Reset the Device:
If your Kindle Fire won't move, this doesn't necessarily mean that it's "broken" or has a major problem. The Kindle Fire has a tendency to become "stuck," meaning that it looks like it's "off" when it's actually "on" but it will not work properly because it's locked up. To unlock the Kindle Fire, do a reset by holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to get the Kindle Fire up and working again.
Charge It:
If resetting doesn't work, it's possible that your battery is dead. Try plugging the Kindle Fire into the charger and wait about 15 minutes before trying to turn it on again. If the device refuses to start up, try resetting it again.
If it still won't move, it's possible that you have a dead charging cable. Alas, the cables that come with the Kindle Fire are not known for their longevity. Try charging the tablet with another cord that has a Micro USB connection and see if the device responds. There's no guarantee that the charging cord from your smartphone will work with the Kindle Fire, but it's worth a try. If you get a bit of a charge, then you'll know that your Kindle Fire needs a new charging cable.
Try a Different Power Source:
if the charging cable appears to be working but the tablet still won't move, try plugging it into a different power outlet or the USB port on your computer.
If all of these troubleshooting tips fail, your Kindle Fire may have a hardware problem that requires professional help.
Visit here:
Kindle Fire Support
1helpful
I didn't realize that was putting a pass word n .How can I open my kindle/
Forgot my password
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
How to unlock kindle fire
Forgot my password
2answers
How do I receive my kindle books when my email address is different?
I assume you mean kindle books you order online (not from the kindle itself?)
They are delivered to your Kindle based on what you have registered on line, not to your email. Therefore changing your email address should not matter (at least directly).
When you say 'moved' - do you mean moved house physically (which does not matter at all) or moved to using a new kindle? Assuming you mean a new kindle, you need to
A) make sure the kindle is registered to your Amazon account: go to home screen, touch top of screen to bring up menu and then press the 'three lines button', select settings. There should be option to register (you will need email address and password - so you need to make sure your online Amazon account has correct email address registered! This is where email change might be causing problems, but can be updated online)
B) when you order books online you need to select the correct kindle to deliver to in the drop down box next to the order button (it might be called something like "Paul's Second kindle")
You can access all books you have ever bought (for this kindle or any other) on Kindle paper white by selecting 'cloud' when on the list of books at home screen.
Hope that helps, if not please reply and explain in more detail what you are doing and what happens / does not happen
My kindle says "battery STOPPED" what does this mean?
The message indicates the device believes your battery to be faulty and will not charge it anymore for security reasons. The Kindle's assessment of the battery state may be a glitch I've seen reported several times and there may be a way to fix the situation:
You can try a hard reset of your device: press and hold the power switch for 30 seconds, then release it and wait for the Kindle to turn off. Then turn it on again. See if the issue is gone.
If this does not help, there is a known issue with the "Battery Pro" app. If you have it installed, remove the app and restart the device.
Last resort is to contact Amazon Kindle support via http://www.amazon.com/kindlesupport and clicking the "Contact Us" button (its yellow).
Kindle is stuck - I cannot turn page or shut down even with reboot
Then it means files of the Kindle Operating system might be corrupted in the Device. You need to reinstall the operating system in the kindle support. You can ask for the Support Kindle Technical Support Registration 877 690 9305
My kindle reader will not power on
Make sure that the kindle is fully charged. When plugged into the wall the yellow led will light up as it is charging. When it turns green, it means the kindle is fully charged.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
