CRONY BRAND
SOURCE: GPS map 60cs does not recognise my unlocked Taiwan City Navigator
I finally downloaded the jetmouse v1.3 key generator and the key it provided worked perfectly. I installed the map on my GPS and now I can drive around Taiwan like a local; always knowing where I am going. Sweeeeeeeeeeeeeeeeeeeeeeetness.
SOURCE: i have a garmin gps72
You need to find what Map Datum your map is using, it should be printed in the margin or the title of the map. Then you need to set the Map Datum the same value in the GPS 72 (Main menu, Location Tab). Most modern maps and charts use WGS84 but I wouldn't know for Saudi Arabia.
SOURCE: International Maps for Magellan Maestro 4250 GPS
If I am correct you can put it on the sd card
There should be a slot for the card on the unit .
also you can check on their web page .
SOURCE: Formating the Zumo 550 GPS
Hi, I had a very similar problem with my Zumo 550. It turned out to be the SD card. I had an 8gb card full of MP3 tracks and the unit indexes them before working properly.
I removed the SD card all was well again
SOURCE: I AM UNABLE TO DOWNLOAD THE SAUDI ARABIA MAP,
u can download at the uniden website :) good luck!
