Question about HTC Cell Phones
How do I turn off safe mode on my HTC Explorer?
Posted by jenadams78 on
s.a piumal madusanka
How do i get the phone out of safe mode
Posted on Apr 07, 2013
Htc one sv stuck in safe mode volume buttons inoperable
Turn off the device. Remove the battery, hold the power button down for 5 to 10 seconds. Reinstall the battery, this should reset the device back to normal. Hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
Jul 16, 2014 | HTC One SV
Reset
There are 2 modes for resetting, on the screen, and a hardware reset. I hope the following link works for you.
http://www.htc.com/www/support/htc-explorer/howto/91346.html
May 16, 2014 | HTC Explorer A310e Android 2.3 Unlocked...
Get htc rhyme out of safe mode
How do you turn the HTC RHYME out of safe mode!
Aug 15, 2013 | HTC Rhyme
How to remove safe mode on htc salsa
I dont have a home butten u have to slide it up
Jan 19, 2013 | HTC Salsa Smartphone
Hard drive not showing in explorer
Maybe a virus has hidden it. It seems like you are booting up ok and everything seems to be normal since you are able to run explorer. The drive is there otherwise you wouldn't be able to run explorer.
Try booting up in safe mode then checking explorer or click Start/My Computer to see if the drive is there.
Turn off your computer, then hit the power button to turn it on and immediately start hitting the F8 key repeatedly until you see Safe Mode. Select Safe Mode and let it boot up. Things will look different in safe mode. The desktop will be darker and the icons bigger, this is normal.
Mar 31, 2012 | Computers & Internet
Htc stuck in safe mode
I can't install software's, I have problem with safe mode and one more thing my key button is not working. Get me solution
Jan 04, 2012 | HTC Wildfire S Smartphone
HTC phone in safe mode, can this be fixed
Hi, When you're done troubleshooting problems with your HTC Hero in Safe Mode,
you will need to go through steps to boot it regularly and remove it from Safe Mode.
To do so, turn off the phone. Then while its off, hold the Menu and Power until the phone boots. The Hero should then no longer be in Safe Mode
Start the phone and uninstall apps in safe mode
If your phone keeps restarting, or it starts up but does not display the Home screen, a recently installed application may be causing the issue.
When this happens, try starting up your phone in safe mode. In this mode, your phone does not run any third-party applications. Safe mode allows you to start up your phone successfully so you can uninstall any applications that you have recently installed or which may be stopping your phone from starting up correctly.
To start up your phone in safe mode, press the END CALL/POWER button and hold the MENU button until your phone restarts and displays the Home Screen. You will see "Safe mode" displayed at the bottom-left side of your phone screen. When your phone is in safe mode, follow the same steps in Removing installed apps to uninstall the third-party applications.
After you finish uninstalling the applications, restart your phone and check if the issue is resolved.
Hope it helped.
Thanks for using fixya....
Jan 10, 2011 | HTC Droid Eris by
Safe mode on g1 wont go away
press the red phone button and choose turn off then press ok when the next window comes up and the phone will shut down.try and turn it back on wait for it to load up and you should be good to go
May 31, 2010 | HTC G1
The safe mode is on how do I remove it
Using the safe mode feature on your T-Mobile G1 will allow you to easily pin point an issue you are experiencing with the device. Follow these steps to enable and disable the safe mode feature.
  1. HOW TO TAKE YOUR T-MOBILE G1 OUT OF SAFE MODE
    If you have found yourself in safe mode and don't know how to turn it off, or if you are finished troubleshooting, turn your device off as you usually would. When you restart the T-Mobile G1 should not be in safe mode anymore.
  2. If the T-Mobile G1 is still in safe mode when you restart, there is something else wrong with your device. At this point you will need to contact technical support to assist in diagnosing the issue.
Nov 14, 2009 | HTC G1
Cell Phones Logo
487 people viewed this question
Top HTC Cell Phones Experts
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Marvin
Marvin
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
