Question about Toshiba Satellite A215-S5818 Notebook
Monitor comes up black i can see the cursor but nothing else any ideas? it boots normally but once past the boot screen its all black with just the cursor showing
It starts up normal goes through the boot process and you can see the status bar and everything else but once it is done it goes to a black screen. you can see the cursor but it will not show icons or background. and i cannot go to control panel or anything like that. i can access the bios and boot menu but thats about all
  • Greg Jan 12, 2012
    Please clarify, does it boot into Windows at all, or does it say its starting and goes black with a blinking cursor?
  • Greg Jan 12, 2012
    Nevermind the more I thought about it, your not getting to the operating system. The PCs used to say something to the effect of 'operating system not found' after the POST if it could not find a boot device. I think that's what's happening here, you have to go into to BIOS and see if it can detect the hard drive. When the laptop boots look for a message saying 'press F1 for setup' or something along those lines... if it comes up too quick to see start hitting F1, Esc, Del keys right after the power lights comes on, BIOS is usually one of those keys. Once in BIOS look for a 'devices' type tab and search for where it reads the hard drive If there's nothing there then its your problem, and you need to get the BIOS to autodetect it. Respond if you have questions.
    Scholar:
    New Friend:
  • 52 Answers
Posted on Jan 12, 2012
Testimonial: "ok that part the pc recgonized the hdd but the processor fan did not turn on at all and it still goes black could it be a motherboard or video card problem?"
  • Greg Jan 12, 2012
    If the fan is not spinning on I am leaning toward a motherboard issue since it controls the fan. I googled your model and found the following links, although from what I read this person's fan did spin. There was a whole section on black screen troubleshooting, looks like a very through article, so good I bookmarked it. Let me know once u follow the article if any of it helped, but if none of it works, you may want to look at replacing the motherboard.
    black screen troubleshooting issueshttp://www.techsupportforum.com/forums/f...
    original threadhttp://www.techsupportforum.com/forums/f...
Toshiba Tecra M5 Boot Problems
man you push alt+ Ctrl +p so you can get it the Bios specially where has been saw it the flash cursor you will see now BIOS normally
Jun 30, 2012 | Toshiba Computers & Internet
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
Dell Inspiron 1501 - black screen periodically
Hi,your problem could be as a result of a bad screen or screen connector(Flex)have a technician look at it.
Jan 02, 2010 | Computers & Internet
HP Pavillion dv9000 will not boot up in normal mode, only safe.
Have you tried an XP repair?
Then you can save your data .
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 18, 2009 | HP Pavilion dv6208nr Notebook
My Asus eee PC fails to boot
Reboot the system
Press F8 at boot startup. In the boot menu
Choose Last Known Good Configuration. If this doesn't work
Try Safe Mode
Go to Device Manager
Roll Back any new driver you've installed
and/or
Go to Add/Remove programs
Unistall any new software you've installed
Mar 31, 2009 | ASUS Eee PC 701 Notebook
Can't get past black screen and mouse
Power off your computer, then power on hitting F12, del or whichever key it states to go into setup. From the setup menu, select change boot order or boot menu. Set the CD ROM to the first boot device. Save changes. Restart. Your computer should boot to cd starting the installation.
Feb 06, 2009 | Dell Inspiron 1501 Notebook
Black screen with cursor acer aspire 5315
start your laptop in a safe mode by pressing f8 during booting, the restore your system to a back date where its working fine
Sep 30, 2008 | Acer Aspire 5315 Notebook
Toshiba Satellite A215-S5818 Notebook Logo
230 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
