SOURCE: Sony VAIO PCV-W700G Desktop PC
My vaio deshtop cant boot from cd, no boot screen i do not know how to go to bios, i try to press "del", "F9, 10, 11, 12." still cant help. Another problem it cant give sound, window sound was disable.
Please help me at [email protected]
SOURCE: Sony vaio cpu is makes a lot of noise
I actually have the very same computer, PCV-RS720G, the best solution is to just upgrade the fan. The easiest thing to do is to take the fan out of the Vaio and bring it with you to Microcenter or whatever your local equivalent is and ask someone in the store for a compatable fan. Unless you feel comfortable ordering on line. I would suggest something with 3 speeds and 9 blades. Silicone pegs (instead of screws) would be a big plus.
SOURCE: Hard Disk Crash
If you have replaced HDD of your machine, then there is no otherway to get your things back rather than installing them. If you have CDs from Sony, then you are safe.
SOURCE: how to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
About how old would you guess your computer to be? Is it under warranty? What version of Windows do you have?Can you please describe what happens when you turn the computer on? Any noises, words displayed on the screen, etc.?
