Krups Dolce Gusto KP 2100 Espresso Machine Logo
How to replace the seal between machine and capsule.
The seal between machine and the capsule is damaged and some part of the water not go through the capsule but directly to the coffee cup. I could dismount the back side of the machine but I am not able to get to the head of the machine, where the capsules are fed into the machine and to replace the seal were the needle is. I am not able to dismount the plastic cover of this part, as I am afraid to break it forcing it with the screw driver.
2 Related Answers
Anonymous
  • Posted on Feb 05, 2010
SOURCE: machine is not puncturing coffee capsule
Descaled machine and appears to be now working.
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Feb 06, 2012
SOURCE: I have a Krups Nescafe Dulce Gusto coffee maker which spurts a lot of water around the capsule in it but doesn't get any in the cup and only spirts water where can I take it to get it fixed in Calgary
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
1helpful
No pressure Miele cva 2650
If your Miele CVA 2650 coffee machine is not producing any pressure, it is possible that there may be a problem with the pump or with the water supply system. Here are a few steps you can try to troubleshoot the problem:
  1. Check the water tank and water lines for any visible signs of damage or blockages. Make sure that the water tank is properly seated and that the water lines are securely connected.
  2. Check the seals on the machine, such as the gasket on the steam wand and the seals on the water pump and boiler. Make sure that these seals are properly installed and not damaged.
  3. If the issue persists, it is possible that there may be a problem with the water pump or another internal component of the machine. In this case, it will likely be necessary to have a qualified technician inspect the machine to diagnose the problem and recommend the necessary repairs.
I hope this information is helpful. Let me know if you have any other questions or if there is anything else I can assist with.
My nescafe dolce gusto mini me is leaking milk from the bottom so some milk is going into the cup and the rest on the worktop. Any ideas?
If your Nescafe Dolce Gusto Mini Me is leaking milk from the bottom, there may be a few possible causes:
  1. Check the milk capsule: Make sure that the milk capsule is inserted properly and is not damaged. If the capsule is damaged, it may cause leakage.
  2. Check the milk frother: If the milk frother is clogged or not working properly, it may cause the milk to leak from the bottom. Try cleaning the frother and see if the problem persists.
  3. Check the machine: Check the machine for any cracks or damages that may cause the milk to leak. Also, make sure that the water tank and drip tray are properly in place.
  4. Contact customer support: If none of the above solutions work, contact the Nescafe Dolce Gusto customer support for assistance.
In any case, make sure to clean up any spilled milk thoroughly to avoid any safety hazards.
Nespresso too much water sometimes
It's normal that some of the water or and coffee flows drops into the capsule container. Mostly it will occur when you do not insert a capsule into the machine, and the rewing unit is not sealed with the capsule. The capsule container can hold up to 5 or 6 used capsule.
1helpful
Delonghi Nespresso Coffee Machine Model EN66 After years of great use our machine now has small drips from the main coffee/water spout after use.
Try running apple cider vinegar through it. A few times. This is a mild acid that will get rid of mineral deposits from water. I do this on my coffee maker. Run straight water a few times after to get rid of the vinegar taste.
My Nespresso Xn250140 U doesn't work. Why?
Check the hole where you put the capsule, are there any faults or obstructions visible? If not be very suspicious of your capsules, there are lots of brands of Nespresso coffeemakers and the capsules have slight variations between the different brands. The variations are almost invisible but enough to prevent the wrong capsules being used.
Nespresso U, coffee does not come out the spout, goes down into the capsule bin.
Please read this
https://www.thedebuguy.com/blog/debugging-nespresso-machine
My Lavazza Blue coffee machine does not press enough to punch the holes. The coffee comes out water. What should I do.
After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
19helpful
3answers
My machine leaks water into the capsul box and doesn't punch holes or not enough in the capsule when pushing it in. Coffee is very weak because not enough coffee is reached in the capsule and water is...
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
3helpful
With our nespresso machine, when you place the capsule inside & press the button the water runs through the inside of the machine where the plexiglass basket for the empty capsules are
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
