This surround sound system was given to me by a close friend before he emigrated. I never thought to check if all of the speakers were there. Turns out that I am missing the rear-left speaker. Only two speakers and the sub work. If I was to somehow find a replacement rear-left speaker for the set, would to other speakers then work again, or is there a bigger issue at hand here?? Many thanks, Joanne
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
SOURCE: Logitech x540 speakers- rear speakers distorted on matrix mode
i have the exactly the same problem .. my rear speakers are only supporting the music but not when a singings come in from a song .. and it isnt as loud as my front speakers when it is the same watts ( 2 x 7.4W )
SOURCE: x-540 speakers no sound rear speakers
rear speakers are not designed to put out the same output as fronts. They are for supplemental sound only, to make it seem like there's something happening behind you.
