eMachines ET1641-02w (PT.NA60X.001) PC Desktop Logo
Anonymous Posted on Jan 11, 2012
MCP73VT-PM Got up one morning and nothing on screen even though powered up. I tested ps then swappped memory and another cpu. Hd powers up but nothing on monitor no sound or picture. I even pulled out pci cards. any ideas
  • 5 more comments
  • Anonymous Jan 11, 2012
    Does it have integrated video card or an independant video card?
  • GI Consulting Jan 11, 2012
    No POST beeps?  That's not a great sign IMHO.My best guess is that your mainboard has died.  Inspect the board, especially capacitors around where the PSU / Power Supply Unit connects to the board.  You may notice them bulging and/or leaking.In my mind, anymore, if I'm going to bother swapping a CPU, I'm likely going to be swapping the mainboard as well (because I will be upgrading).
  • Anonymous Jan 12, 2012
    intergraded graphics card I tried an older card I had but still nothing. no beeps except when I pull all memory out. I havent noticed any swollen or leaking capacitors.
  • GI Consulting Jan 12, 2012
    When everything is working properly, there should be one beep approximately right before you see the Windows logo appear. If it never did that during the entire time you've owned it, then I would presume it was disabled in BIOS settings (some computers have the option and some do not).
    I'm sorry to say you may be in the market for a new computer, unless your eMachine is under warranty.
    Amazon.com: Windows 7 Home Premium Computers ~$299 and Up
    http://www.amazon.com/mn/search/?_encodi..."
    If my theory is right then what could happen while you were sleeping the was a high voltage wave into the outlet plug and that probably made a electrostatic wave and screwed on the motherboard.
  • Roberto lopez Jan 05, 2022
    emachine ET1831-01
    manual
    https://www.manualslib.com/products/Emac...
    I found the manual for the emachine
    ET-1831-01
    emachine ET1831-01
    manual
Phil Smith
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Nov 28, 2014
Phil Smith
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
5608
Points
11
It's a very old thread but I just wanted to leave some info because nearly 1000 people have read it so far . . . .
It's extremely rare that a mainboard will just die suddenly without reason - I've seen 2 in the past 10+ years. All others have just needed a quick fix and are generally affected by overheating, faulty RAM, CPU, CMOS battery flat (does stop some things booting), stuck keys (usually causes beeping but not always), badly seated video card or other PCI card, or the biggest problem of them all - a faulty capacitor.
The motherboard mentioned (MCP73VT-PM) has 4 main capacitors, an on-board speaker, and no option to turn off the speaker in the BIOS - so when testing, if you don't hear a single beep after 3 seconds, it's still not working properly. If you remove all RAM fitted and turn it on, it 'should' give a constant beeeeep till you turn it off again - this shows the board is testing for memory okay, and indicates it's likely the capacitor problem.
Most faults can be narrowed down by trying a known working spare part, but if all else fails, I go for changing any of the larger sizes of capacitor on the mainboard. Capacitors are the most dodgy of all components and can easily go faulty at any time, and don't always show any signs of a problem (they don't have to leak or expand).
Smaller sized capacitors rarely have a problem, but the larger sizes (physical size I mean) like 10mm wide, with any voltage and any UF - these can easily just stop working properly. It doesn't take a voltage surge/spike or overuse, or heat, or cold. These things can just stop for no good reason.
If your mainboard is worth keeping, just remove all of the bigger capactors and solder new ones in. It can be well worth it, generally expect to pay about £5 for 4 (depending on the values and the manufacturer). The board mentioned here has 3 x 16volt 1800uf, and a single 6.3volt 1800uf - it's easier to just replace all 4 items I think, rather than mess about testing each.
I hope that helps others who find this question.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 28, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1650
Points
MCP73VT-PM dont buy a pc with this board in it.I have had 7 in my shop these last 2 months.The board fails after abut 15 months.
Anonymous
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Jan 12, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
19764
Points
148
Mmm that's not a good sign since the computer have integrated video card there a little chance that your motherboard has died, everything you would hear that is power on because the power supply do work properly but if the monitor doesn't show anything or do not hear any beeps, that probably means that your motherboard is dead.
Mcp73vt-pm bios
HI I WANT UNLOCK THE BIOS OF MY MOTHERBOARD bios for MCP73VT-PM PACKARD BELL SOMEONE TO HELP?
My pc turns on and inmediately turns off
see if the fan on cpu is working make sure that the cpu has cooling grease. if the heatsink not big enought it will shut down just like that ok
1helpful
I have a MSI MS-6566 Ultra-C v1 with an Intel 2.6MHz CPU. The board is getting power and the CPU fan is running along with the fan on the AGP video card, but the CMOS will not post. The PSU tests fine. ...
have a problem with v1.5 a6566ims always ask if in start setting bios date month and year, and the second when the computer restarted there was no display on the monitor even though I have changed battere, VGA or memory, whether the BIOS has been damaged? what should i do please help. thanks
No screen activity
If you used an external monitor and got nothing on it, then the problem is the video card.
2helpful
Trying to find interal connectors 2-1 pin audio spdif on a emachine 1831-05. motherboard is mcp73vt-pm
It has been stated from my sources, that the ECS GF7050VT-M5 mobo, is the same as the ECS MCP73VT-PM, with a slight difference.
The difference being that the MCP73VT-PM mobo is based on the Micro-ATX form factor, and the GF7050VT-M5 is based on the ATX form factor.
[ Micro-ATX form factor size is 9.6 inches by 9.6 inches. 9.6 inches is approximately 9 and 9/16ths inches. It's also 244mm by 244mm.
ATX form factor is 12 inches by 9.6 inches. 305mm by 244mm ]
ECS MCP73VT-PM,
http://www.e4allupgraders.info/dir1/motherboards/socket775/ecsMCP73VT-PM.shtml
ECS GF7050VT-M5,
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=858&CategoryID=1&DetailName=Manual&MenuID=1&LanID=0
To the right of the subheading - Download, left-click on the server location nearest you.
[Taiwan, USA, Europe, China ]
This is a PDF file download. (Motherboard Manual) May take a few seconds before you see the first page, and additional time for the file to fully download.
Suggest you let the file download all the way, before looking through it.
I'm also looking at an ECS MCP73VT-PM on Ebay, as well as the PDF motherboard manual for the ECS GF7050VT-M5.
Motherboard oriented so that the Processor is to the top, ram memory slots to the right, and the orange PCI Express x16 slot to the bottom, the SP/DIF header on the GF7050VT-M5 is located to the left of the PCI Express slot.
From the poor view on the Ebay link, the MCP73VT-PM also seems to have the SP/DIF header in the same location, but clocked differently.
The header is clocked perpendicular to the orange PCI Express x16 slot, while on the GF7050VT-M5 the SP/DIF header is parallel to the PCI Express x16 slot.
The header is 4 pins long, with 1 pin not installed.
Pin 1 is marked on the motherboard.
Pin 1 is SP/DIF Digital Output
Pin 2 is +5VA ( 5 Volt analog power)
Pin 4 is Ground
There is no Pin 3.
Asus P4T-M version 1.05 Not Posting?
Hi ed, that 4-Pin ATX_12 connector near the CPU is for powering the CPU. Suggest you change PSU's. Though I'd agree there are some boards that have the 4-Pin connector & it's not used. Those boards usually have a 24 pin main connector & lower voltage CPU's Please check here at Asus web site for P4T-M.
http://support.asus.com/download/download.aspx?modelname=M2A-VM&SLanguage=en-us
Related FAQ's P4T-M
http://support.asus.com/download/download.aspx?SLanguage=en-us
I'm sure your P4T-M will boot after connecting the ATXPWR, ATX12V. As you noted, it would be nice if you could test the memory. When you get display you can test your memory for free by downloading a mem test program at. http://www.memtest.org/
Enjoy the weekend Ed.
Mike
Logo screen, but no POST test
Try removing all unneeded hardware leaving only the core components needed to see your board post (processor, memory, motherboard and external video if your board doesn't have onboard) see if it now posts. check to make sure your hardware is installed correctly (memory is seated and processor & heatsink are firmly inplace) Is your new board bigger than the old one? does it make any contact with the case behind the board causing it to short? You could also try your processor in another board. Good Luck
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
